Question about Husqvarna 28cc Gas Line Trimmer
I need the specs on the fuel , the H and the L and the T settings
  • Roy Cagle
    Roy Cagle Nov 07, 2010
    Can you please post the manufacturer and model of the carburetor on your timmer? The parts breakdown lists don't have it and some don't even list your model. Please include the manufacturing date or year you bought the machine. If using Husqvarna oil 50:1 mix ratio, if not using their oil 33:1 your manual says.
HHand L take the screws all the way in not to tight and start with 2.5 turns out
Posted on Nov 09, 2010
1999 ford crown vic won't start. changed fuel
Maybe your problem is with the one or many injectors, if just one is bad, you will have problems. Get yourself a multimeter and set it to read in ohms and find what spec the injectors should be at. If out of spec, then you need to replace that one injector(s).
Mar 25, 2013 | Cars & Trucks
54 corvette blue flame 6 cyl tappett adjustment specs hot or cold
Hello bandm fuel: My name is Roger and I will help you.I have checked the 1957 Motor Auto Repair Manuel and the specs listed are for a hot engine only. The intake set at.008 hot and the exhaust set at .020 hot. Should you need further help please just ask. Please rate the answer. Thank You for using and trusting Fix Ya with your repair questions. Enjoy the ride. Roger
Dec 23, 2010 | Chevrolet Corvette Cars & Trucks
Fuel pump pressure specs
The fuel pump specs are 14 psi. and 20 gallons an hour.
Sep 08, 2009 | 1991 Chevrolet S-10 Blazer
Need fuel pressure info
fuel pressure specs are as follows:
5.0 &5.7L 60-66 psi
7.4L 55-62 psi
Jul 07, 2009 | 2000 Chevrolet Silverado 1500
22r carb dumping fuel at 2500 rpm will not pass smog.Was rebuilt and is in smog specs. at idle.
Fill the tank up but do not top off.
Ran the trunk for 15-20 minutes on the highway and recheck the fuel surge condition at 2500 rpm.
If it stop surging then you has a weak fuel pump.
Change the fuel filter will also help.
Also check the fast idle setting.
If everything checks out then set a smog check appointment in the EARLY MORNING.
Jul 05, 2009 | 1986 Toyota Pickup 4WD
Need pressure spec for fuel pump on carburated 89 accord
need to know how to change the fuel pump, do i have to drop the fuel tank or can i get to it from under the back seat
Jul 26, 2008 | 1989 Honda Accord 4 Door
Fuel pump
With a vehicle that old I think you should retrofit any pump that matches within reason the original specs as with throttle body injection fuel pressure is critical. If it is the same as South Africa the agent will sell you any **** to get rid of you. Try fitting a Bosch pump with a pressure regulator (set it to spec ). Please change the filter.
Jun 10, 2008 | 1989 Nissan Hardbody King
Husqvarna 28cc Gas Line Trimmer Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
