Question about Kodak EasyShare C310 Digital Camera
Taking a close up of an item 6" long is not
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
According to the manual, the C310 has a fixed-focus lens with a working range of 0.85 m (about 33 inches) to infinity. So, anything only ten inches from the camera will be out of focus.
Posted on Jun 23, 2011
Where can I dowload the assembling instructions for the Alessia bedroom range model 926
If they look like the image. The 2 screws are the mounting holes, you screw those to the top of the door. Edge of metal support alined with the edge of the door, both in the same position one at the front corner of the door and the other at the back corner. The roller is mounted with a screw through the diagonal slot on the side. There are 3 positions. You place it in whichever position you need so it clears the floor. The highest position will give you the least floor clearance, the lowest will give you the most floor clearance. Normally both rollers are in the same position, unless your floor is not level.
May 09, 2014 | Slide-Co Sliding Wardrobe Door Roller For...
Focusing problems
Hello Samaro,
This effect is produced when the tho sides of the binoculars are not focusing the same.
Since you sayit is present at long distance, it might be that one barrel is stuck and is not focusing the same as the otherone when you scroll the middle "focuser".
What you can do is open it up and try to clean it, also see if there is something, that is making one of the lenses not move forward as far as the other one.
Good luck,
Dahaka
Jul 28, 2008 | Fujinon CD Binocular
I cannot get a clear picture of a ring...what setting do I use...always have trouble with small items
Switch to macro mode. Press cursor-up (marked with a flower) then select Macro (the flower icon). This mode is used for close-up photography. For full details, see "Setting Focus" on page 28 of this manual.
Nov 18, 2012 | Pentax Optio 60 Digital Camera
It won't take pictures sometimes. push the shutter button and nothing happens.
The Nikon D40 in Auto Focus mode will only allow the shutter to operate when the image is in focus. When looking through the viewfinder, the bottom edge provides information relative to what you are looking at. See the image below:
Item 2 is the focus indicator. It must be illuminated to allow the shutter to release. If it is not illuminated, the lens has not been able to determine the correct focus. This can happen when attempting to take a picture in low light conditions. Make sure that the front facing "focus assist lamp" on the camera (between the shutter release and lens) has not been blocked or disabled (Settings Menu # 09) and try again. Many times, you will see and or hear the lens "hunt" for proper focus - the lens will travel from one end of its focus range to the other trying to find focus. When it can't, it stops and prevents the shutter from releasing. You can get around this "unable to focus" issue by changing the position of the switch on the lens to "Manual Focus" mode, detailed below:
If a lens has an "A - M" switch, move it to "M" to manually focus. If the switch says "M/A - M " then leave on M/A (unless you're going to be taking several or more in manual mode), as these lenses may be focused manually at any time in either position. As soon as you tap the shutter button in M/A you return to autofocus.
More advanced lenses, like the 18-200mm, 70-300mm VR and 18-135mm, and any lens with an M/A position, may be focused manually at any time without moving any switches. Leave them in their A or A/M positions.
I hope this helps and good luck!
Jun 13, 2011 | Nikon D40x Digital Camera
"Protected Card"
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
May 08, 2009 | Fuji FinePix S7000 Digital Camera
Pictures are blurred around the edges
Have you tried to change the settings like to scenery or adjusted for lighting that could have an effect. The only time it's blurry for me is when I don't adjust for the picture I am taking. The camera itself focuses so maybe there hasn't been enough time for it to focus. Try those things and if it doesn't work I would take it in to a camera shop maybe it has internal problems.
Sep 27, 2008 | Nikon Coolpix S51c Digital Camera
Pic is fuzzy when taking close up shote of small items (EOM)
Dear MrClean:
You didn't mention what kind of set up you were using or what parameters you have there in your shooting session so I will just give you my two cents worth on how I'd go about doing such a project.
When I used to do shoots for my ebay auctions I used a digital camera in combination with a tripod as hand-held macro phtography can be difficult at best. To get the best results I would recommend the following:
1. Use a tripod since flash photography in macro mode often
results in improperly illuminated or overexposed pictures.
Therefore you will need to be absolutely still in order to get
clear pictures. Therefore set your flash to NOT fire!
2. Remember that macro mode on your G3 means that you
MUST shoot between 1/2" and 1.6ft. Any closer or further and
your picstures will be out of focus.
3. I suggest you shoot in the (P)rogram autoexposure mode as
it allows for manual focus if necessary.
4. If you cannot achieve good focus using autofocus (your
bottom indicator light near the viewfinder blinks yellow) then
try switching to Manual Focus (the MF button on the back of
your camera to the right of the viewfinder). Use the camera's
Main Dial to focus manually. It is located in front of the
shutter button at the top of the hand grip.
5. To ensure the least amount of camera movement use your
self timer to trip the shutter.
6. Try setting up artificial lights (photoflood or whatever you have
available) at 45% angles to your subject for the best results.
If you do these things I think you'll get the results you're looking for.
Hope this helps.
Sincerely,
HeavyDLB
Jun 09, 2008 | Canon PowerShot G3 Digital Camera
Kodak EasyShare C310 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
