Question about Atari 2600 Console
I plug my atari controller into the system and the button works but the joystick does not. No matter which direction I try to move in the character remains motionless. I have tried multiple controllers including paddles and a two I bought at a store that tests their equipment. Is there any quick fix, or something I am doing wrong? Thanks, Kevin
    President:
  • 894 Answers
Well it might be the controllers ports inside of the system that are broken then so you could
try and resolder the controller ports if not buy a new one then.
Posted on Jul 22, 2011
I just hooked up Atari 7. Only one joystick works. any suggestions
JUST UNPLUG IT, BLOW IT , REMOVER DUSTS AND CLEAN THE JOYSTICK PAD AND PLUG IN AFTER SOME TIME AND TRY TO CHANGE THE PORT FROM WHERE YOU PLUG IT BEFORE TO ANOTHER PORT, TO SEE IF IT MAY BE FROM THE PORT.
THANK YOU
Nov 18, 2017 | Atari Video Game Consoles & Games
One PS2 controller doesn't work good and screws my other one
This is usually a matter of cleaning. If the nodes on either your controller end or the system itself are dirty you could have a bad connection that would cause your controller to all kinds of wacky stuff. Use some cleaner like alcohol and a q-tip and clean the ends. If that doesn't work your proabably better off buying a new controler then trying to fix it.
Apr 16, 2014 | Sony PlayStation 2 (PS2) Console
Does the Atari 5200 have the same controller as the Atari 2600?
It does use a slightly different controller. The joystick that comes with the Atari 5200 has 360 degrees of control while the Atari 2600 controler only give you 8 ways of motion. Teh 5200 also has a number pad and buttons for start, pause and reset.
Dec 16, 2013 | Video Game Consoles & Games
Regardless of controller on the left controller port i cant move up
Well it sounds like the controller that you have is not working properly so you could buy a new controller then. Lukie games sells atari 2600 stuff. Or you could open up the controller and try re soldering it the. To see if it works
Apr 29, 2012 | Atari 2600 Console
I was just given an Atari 2600 for Christmas and the controllers do not work. The red trigger button works but the joystick does not, on either side. Is this something that can be corrected or is the...
it has dirty contacts so you unscrew the bottom then put some contact cleaner in it then move the joystick around alot for a good 5 minuets so the cleaner will clean it then the joystick will work
Jan 01, 2011 | Atari 2600 Console
Ps2 - characters moving on own
I had the same problem before. Its called joystick/button lock. You need new controllers. Happy Dance!
Dec 21, 2009 | Sony PlayStation 2 (PS2) Console
Atari 2600 problem with left control plug on console
Well maybe the controller ports need to be resoldered then try soldering then with a solder iron.
Nov 21, 2009 | Atari 2600 Console
Possible Control Port Issue for 2600
Superdrafan:
you sound like you have a conection problem within you atari
open the Atari up and look to see if there are any dry solder joints from the joystick ports
just dabbing the point with a solder iron shold freshen up the connection
The Gameboy: you sound like you have dirt in your joystick
open it up and clean the connections with a cloth and spirts
Sep 04, 2008 | Atari 2600 Console
Which Joystick?
YES!
The joystick controllers are backwards compatible with the original 2600 system so you also technically get 2 new 2600 joysticks with this set.
Dec 11, 2007 | Video Game Consoles & Games
Atari 2600 controller problem
I HAVE BEEN REBUILDING ATARI SYSTEMS FOR 20 YEARS AND THOUGHT I HAD SEEN EVERYTHING, AND I WOULD THINK IT TO BE A JOYSTICK PROBLEM. THEY CAN BE REBUILT WITH NEW CONTACTS, BUT I AM THINKING THE PROBLEM MUST BE INTERNAL. I CAN ONLY SUGGEST TRYING ANOTHER DECK. THERE MUST BE SOME PROBLEM WITH THE PINS IN THE PLUG PORT.
IT
Oct 19, 2007 | Atari 2600 Console
Atari 2600 Console Logo
127 people viewed this question
Top Atari Video Game Consoles & Games Experts
Reggie brown
MegaByteMe
MegaByteMe
James Wishart
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
