Question about Samsung RS2630SH Side by Side Refrigerator
I have just bought a samsung fridge when I put it on, the sides of the fridge become slightly hot. any trouble?
  • Samsung Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly. The evaporator lines pass though the cabinet and the heat generated from the cooling process is transmitted to the cabinet. Usually you would also not this same warm to the touch around the door of the unit. Years ago they used to use heating elements to keep condensation from forming around the doors when the door was opened. To make the units more energy efficient they now run the copper tubing around the doors to use to the heat from the refrigeration process to prevent condensation. Unless it is hot.... as in really hot to the touch I would not be concerned. If by chance you are not geting the normal operating temps and the unit is hotter than you thnk it should be then take a look at the condensor fan area and make sure the fan is running and that the condensor cooling tubing is free of lint and debris. (remove fiber board cover in back of the unit to check)
Thanks for choosing FixYa,
Kelly
Posted on Nov 06, 2010
My Samsung side by side RS2534WW is flashing 6 on freezer side and it feels like food is starting to thaw...what can I do?
needs to be minus-17 ..... 6 degrees should be fridge' temperature,
compressor may be hot and cut-out, pull away from wall at least 30cm and let some air to circulate behind to cool Compressor Motor
(possible Faulty Capacitor or Thermostat, )
it may also 'Reset' if turn fridge off for 10 minuites and back on again...have a listen and see if you can hear the Motor going?
if not.....I think your in Trouble!!!!
Aug 19, 2016 | Samsung Refrigerators
My daughter bought back a mini amana fridge it seems too hot on the sides and its on 6 os that normal??
Sorry but I don't recognise the fridge brand. The internet suggests these are not the things called mini fridges but in reality are merely coolers so I guess it is a regular fridge designed to keep stuff between 2 and five degrees C.
Not sure what you mean by 6 os.
Conventional fridge design has a thing at the back that looks like a radiator. This condenser is prone to corrosion and is easily damaged resulting in the loss of refrigerant. Since it was decided all types of refrigerant gas is damaging to our atmosphere, manufacturers have been increasingly burying the radiator thing in the fridge casing where it is protected, often at the sides. Usually the condenser will become quite hot until the fridge interior is down to the required temperature when just maintaining the inside temperature it will vary between warm and cold if the door isn't opened much and the insulation and door seal is in good condition.
Burying the condenser(s) in the casing makes them less efficient at losing heat and so they will become hotter than the conventional old-fashioned design during the interior cooling stage..
I hope this helps and little.
May 15, 2016 | Amana Refrigerators
Inner walls over heating, fridge side stoped working
Here is a tip that I wrote about the reasons why the sides and/or seals could be getting hot on your refrigerator.
Refrigerator Trouble The Outside of Refrigerator Hot
heatman101
Mar 06, 2011 | Samsung RS2630SH Side by Side Refrigerator
Fridge not cooling; fridge temperature staying at 19c. power cool button not changing the temp.
On these models the technicians want to sell you circuit boards and other parts. These parts usually do not solve the problem.
First to get your fridge cold again. Remove all the drawers and shelves on bottom of fridge side and remove
rear panel to inspect coils. If coils are covered in clear ice like a solid block, then thaw/defrost this. A hair dryer helps.
Pour hot hot water into this area when finished until it runs out the drain at the back of fridge. The frozen solid drain is the problem. When finished use blocks to raise front of fridge so it leans slightly back. Supposedly this helps the drain from freezing again. The product is inherently defective and designed poorly, your problem is quite common.
We completely redesigned the drain on ours (not recommened for most people) and it works okay but I cannot wait to replace with a different brand.
Jan 23, 2011 | Samsung RS2534 Side by Side Refrigerator
The middle bar on my side by side refrigirator is very hot!
hi,i want to tell you i don't work on samsung fridges,they just don't give techs any info,you have to work with samsung to get any info but on any other fridge if the strip is hot or really warm either the condenser coil on the bottom is clogged with dust or the condenser fan isn't running to cool off the compressor and blow the hot air across the condenser coil,so remove the bottom front kick panel and see if the coil is clogged,they have had alot of problems with the computer board to so if the board is bad the fan might not be blowing fast enough to cool it down but check it to see if the fan is blowing,pull the fridge out,remove the bottom panel and check the fan,i've seen other machines do this,and the fan has to be ordered,if you get a house fan and blow it on the back where the compressor is it should help cool it down so you don't cook your compressor and you won't loose any food until you get it fixed.i hope this helps you out and good luck,call whoever you bought it from or call samsung and they will send a certified tech there to help you out or go here to look up parts,if it is the fan motor you can replace it if you want to give it a shot.go here put your model number in and look up parts
https://www.searspartsdirect.com/model/search.html?q=lt608
Feb 04, 2018 | Samsung RS2630WW Side by Side Refrigerator
My Samsun RS2534ww side by side refridgerator will not maintain temperature on the fridge side. It consistantly warms up to between 50 and 60 degrees despite resetting the thermostat.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try defrosting the FF as despite common belief these units are not totally frost free.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Nov 06, 2009 | Samsung RS265LABP Side by Side...
Our frig is not cooling but the freezer works fine, it is a hotpoint side by side fri freezer... it made a humming noise for a while but that has stopped.. any help would be appriciated... what the trouble...
In side by sides if the fridge side not working correctly it means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. Best call a service engineer asap.
Oct 07, 2009 | Hotpoint Refrigerators
My fridge is 1 year old and freezer is freezing but fridge dont work
Sep 29, 2009 | Whirlpool GS6NBEXR Side by Side...
Hot refrigerator
I had the exact same problem and got sick and tired of it. I contacted the Consumer Product Safety Commision and they came out and photographed my refrigerator and asked questions about the fridge. If everyone who is having trouble would write the commission we might be able to get the fridge recalled. Even if you repaired it already, they want to know the problem and what you did about it. the web site is: www.cpsc.gov. Everyone please help out. The more people we get to respond the better. ThanksZFH3I10
Dec 28, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
345 people viewed this question
Top Samsung Refrigerators Experts
Paul
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
