Question about Refrigerators
GE Model 26 bottom freezer refrigerator My problem is with the glass tray in the refrigerator portion of the appliance. Below this tray, the crisper drawers slide into place. A carton of orange stored resting on the glass tray leaked, with orange juice accumulating between the glass tray and the frame on which it rests. I thought the glass tray would simply lift off its frame, but it does not. How do I remove it in order to clean the bottom side of the glass, and the frame on which it rests?
SOURCE: How to place back the freezer trays for E522B refrigerator
Make sure to return the correct tray/bin in the right runners. All three freezer trays have different designs on each side, which means that the top tray must be returned to the top tray and cannot be interchanged with the second tray. What happened in my case is, I was trying to put the 2nd tray to the first tray that's why I had difficulty replacing it back and would not fit.
Posted on Mar 23, 2009
SOURCE: Crisper Door broken had the parts I needed (crisper drawer lid and the longer drawer lid.
Posted on Apr 21, 2009
SOURCE: water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Posted on Jun 24, 2009
SOURCE: Water from freezer dripping into fridge freezing and accumulating
Maytag , MZD2752GRW; Water accumulating and is freezing in bottom of the freezer, then runs out the door on to floor.
Posted on Jul 01, 2009
Sea Breeze
  • 4655 Answers
SOURCE: unexplained water accumulation under the crisper/produce
OK, I am going to give you a lot of information on one page, so please read carefully and choose the parts that apply to you. PS, Please rate my solution and my thanks to all the Guru's that helped put the following page together. please click on link below, Thanks Sea Breeze
Posted on Aug 11, 2009
Testimonial: "WOW!!!You can't believe the green stuff that was clogging up that cup!! Thank you Sea Breeze and the Gurus - you saved us from buying a new fridge."
Water below the deli tray
below the cooling element at the back is a groove that drains to a hole - make sure the hole is clear. its safe to use a wooden scewer.
normally this groove and hole are at the same level as the glass shelf.
Good luck
Oct 02, 2013 | GE GFSF6KEXWW 26 French Door Refrigerator...
Frig stopped cooling. Light works, freezer works, can hear freezer fan. Doesnt seem like air flow is getting to fresh food area. Freezer back wall has thin line of frost on it. Model tbx18ja. I want to...
Easiest way is to push against the vertical portion of the ice tray holder until it slides
off the buttons which are inserted into the top of the freezer compartment.
These models sometimes had issues with defrost timers (which I just replaced one today) and Defrost termination thermostats (which is clipped on to a tube behind freezer panel).
Make sure the freezer coils are not frozen up solid, if so use a hair dryer to defrost them
and make sure the vent is not iced over.
Model and serial are in the lower compartment on the left wall. In case you need to go to
the appliance parts store.
Hope this helps.
Aug 02, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
I have a GE model GSS22JERFWW S/N AL243114.The freezer portion doesn't freeze the ice trays and the refrigerator portion doesnt keep anything cold as it should even tuned up to 9 whereas it used to...
Things to check: does the compressor run? Does the fan close to the compressor run? Does the inside fan run? Is the rear wall inside the freezer covered with frost? That would indicate that it is not going into defrost which will have the same result (no air movement). Does this help?
May 20, 2011 | GE Refrigerators
I am thinking about buying a used ge monogram range. Model number ZDP48L4GH3SS. I am trying to find the stats for it, but I am having no luck. Would especially like to know how old it is, what it weighs,...
All in the links below.
GE Appliances Model and Serial Number Locator
Find Your Model & Serial Numbers. Select your product type. Refrigerators & Freezers. Compact and Wine & Beverage Refrigerators · Bottom-Freezer Refrigerators · Chest Freezers · Icemakers · Side-by-Side Refrigerators · Top-Freezer Refrigerators · Upright Freezers. Cooking Products. Advantium Ovens · Cooktops ... Missing: zdp48l4gh3ss
How to Determine the Age or Manufacture Date of a GE Appliance How to Determine the Age or Manufacture Date of a GE Appliance. The manufacturing month and year is coded into the serial number (not the model number) of the appliance. Our serial numbers begin with two ... for further assistance. For information on old RCA appliances, see RCA Appliance Age or Manufacture Date. Missing: zdp48l4gh3ss
Discontinued Models - GE Appliances Discontinued Models · Explore our GE Collections. Our Company. About us. Our Story · Appliance Donation Center · Press Room. Websites. GE Appliances Worldwide · Business to Business · Corporate Website · Careers · Monogram Design Centre ... Missing: zdp48l4gh3ss
Parts for GE ZDP48L4GH3SS Range - > GE > Range Original, high quality parts for GE ZDP48L4GH3SS Range in stock and ready to ship today. 365 days to return any part.
Parts including Gas burners
These are posts about that Range
Weight and Specs will be the same at 538 lbs.
ZDP48N6DWSS GE Monogram 48 Professional Range with 6 Burners and Griddle...
Jan 24, 2018 | GE Monogram ZDP48L4GHSS Dual Fuel...
Refrigerator Noise
Most likely the fan is hitting some frost inside. Defrost the fridge by unplugging it for 24 hours and see if it helps.
GE refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | GE Profile Bottom-Freezer Refrigerator...
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Hanging the Ice Tray
Well so sorrry (not) LOL ! O.K. joke apart , just look at the "ceiling" of ur freezer. U should see some railings if so just mesure the distance in betwing bouth of them and get a ice tray that size. Just fill the tray with with water hagn it and there u go. Good Luck and Happy COLD DRINKS!
Jun 30, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
