Question about Garden
Prime bulb on leaf blower will not pop back out. The bulb is in good condition. The leaf blower will only start on full choke and eventually stalls out. Fuel lines are good and I have torn apart the bulb area on the carb and it appears the fuel is going in and out. I'm at a loss. Also checked the fuel filter for obstructions.
    Problem Solver:
  • 7 Answers
Hi there, The manual primer is a pump and relies on its ability to deform and revert back to it's original shape in order to pull fuel from the tank, through the carb and into the primer bowl when released and pump what's in the bowl back to tank when pressed. The system uses one or lately two valves in the primer body to achieve this pumping action. It looks like your looking in the right area (running only on choke is a clue too) as I suspect that you have a blockage on the suction side ie anywhere between the fuel filter and the primer bowl. It is possible that the fuel lines are collapsing internally under vacuum closing off the fuel supply. Another area to look is the carb itself. You've probably discovered that there is a filter in the carb body on the fuel pump side under the diaphragm - this an extremely fine mesh and can give the appearance of being clean when in fact gummed up. This filter feeds the needle valve which in turn allows fuel into the metering section and then into the air stream via the mixture control screws for high and low speed (H & L) It is possible that the needle valve is sticking and thus also restricting fuel supply. When cleaning carbs out don't use carb cleaner - sounds odd, I know, but most carb cleaners are unsuitable for diaphragm carbs, OK sparingly for the outside but not the inside unless it says on the tin that is safe for diaphragm carbs. Use Brake and Clutch cleaner. Happy hunting !
Posted on Nov 06, 2010
How to start a ryobi200blower blower 200
First , prime the priming bulb about 4 x...
Next put the choke lever in full choke position
Give a couple slow pulls, then a good strong pull...
(The unit should burp, run for a second)
Next put the choke lever in the half choke position
Pull rope
It should start and run, now put the choke lever all the way in the off position and let unit warm up a minute... if when you turn choke off it stalls out, u didn't warm it up enough...
Oct 10, 2015 | Garden
4 lawn mowers same problem wont start until I prime the by hand. Briggs Stratton 917.387500/ 12AV566n01124987/20043/SDSP2245D Will the same primer bulb fit the above mowers.
If its identical it should work ,if not take the old one to a mower shop,to get correct one and make sure the choke is going right on when the cable is in choke position.
Aug 05, 2014 | Ryobi Snap In Primer Bulb Pump 683974 ...
Gas blower starts idles then when choke is opened stalls out. Gas bulb stays deflated when you push it down twice
If its started and idling,why are trying to choke it??????
Don't do that just start blowing dude. Good Luck......
Sep 16, 2013 | Craftsman Garden
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a mtd 3.5hp 21" snow blower it was bought new in 11/06 the problem im having is stalling it starts ok some times other times it stalls and won't run others it will only run at full choke if...
Try running some fuel system cleaner through it. A good choice is Chem Tools Berryman B-12. There are some hardworking solvents in the product that could help you overcome a dirty carburetor. Initially use a good, strong dose. Maybe double what they recommend . (1 oz/gallon). If this doesn't work, the carb will probably need to be removed and inspected and cleaned.
Feb 03, 2011 | Garden
Will not start. I prime the unit by depressing the bulb 7 times, the choke is full and the throttle is full. It simple does not try to start.
take the spark plug out pull the rope and see if gass comes out of thr cylinder which tell you theres to much gas coming out if your getting to much gas pinch your fuel line pull till it starts thenunpinch it if its firing it will start
Nov 05, 2009 | Garden
The best way to start cold husqv leaf blower 145
Most of the small outdoor power equipment that I have used takes the following to start:
1. Prime 6-8 times, or whatever the manual calls for.
2. Choke the carb to full choke.
3. Pull starter rope. It may sputter and die.
4. After it sputters and dies, put the choke on 1/2. Pull a time or 2 more and should start. Run like that 10 seconds or so, then take choke all the way off.
Oct 30, 2009 | Husqvarna Backpack Blower 155 145 Starter...
Echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Apr 06, 2009 | Echo Garden
Garden Logo
132 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
