Question about Toshiba Satellite A105-S4384 Notebook
I keep losing wire wireless connection for a split second. Could it be bad wireless card and to replace do they need to replace entire motherboard?
2 Suggested Answers
donovanm
  • 177 Answers
SOURCE: replaced wireless card need color for wiring main
White shoud be main black should be aux
Posted on May 09, 2010
My Fujitsu wont stay connected to my wireless internet
Maybe the wireless card in the laptop is no good or not strong enough to receive a good strong signal. Try sitting close to the wireless router and see if it loses connection. Does it connect at all and let you on the internet before it loses the signal? If it does not connect at all I'd say you might have an issue with the password or the type of wireless security protocol type you selected to connect with. For example there are different types of wifi security protocol types: (Ex. wep, wpa, wpa2) .
Mar 19, 2012 | Fujitsu Siemens LifeBook E8020 Notebook
How to repair lan if it is keep blinking without any lan wire
If it is onboard lan you would need to send the entire motherboard for LAN repair which is an expensive process.however if it is a LAN card that you have connected seperately in PCI slot, then replacing the same is a much cheaper, easier and better option.
Jan 08, 2012 | Intel D945GTP Motherboard
Acer Extensa 5620: The power supply jack is loose when you plug it into the laptop. Sometimes it will provide power and sometimes it will not (orange battery light on front of laptop goes on & off)....
System check
1. estimate the extent of damage, possibly requires entire board replacement housing the extension power supply modulators, possibly due to physical damage on contact.
2. Aslo check the battery life since could determine the possibilty of substituting power chord from currrent outlets with batteries
The device would not connect to power outlet without a properly functioning battery installed. A depleted battery could not be replaceble by connecting a source out power outlet. each parts of the power complement the entire process of achieving computer experiece.
Consult a technician insisting the replace the entire power system of battery and ac adapters and also fixing damages on the mother board may be contributing to power leakage
Dec 02, 2010 | Acer Extensa 5620 Notebook PC
My belkin n series keeps losing internet connection hard wired to my computer and three wireless computers in the house. when hard wired to the virgin broadband modem everything works fine
I would suggest taking a look at your modem LEDs. What happens exactly when you lose connection? A look at the LEDs should give you some thought as what might be causing this. You can also try resetting your Belkin to default factory settings by pressing the Reset button at the back for 30 seconds, and then putting back your Belkin settings.
Nov 16, 2010 | Belkin N1 Wireless-N Wireless Router
Keep losing connection
hi there, since no one in your network is experiencing the problem, possible cause would be the wireless adapter of your laptop. try to reinstall your wireless network card driver and observe if you will be getting the same issue. if same issue occured, then you have to call your manufacturer for replacement of the wireless card
Apr 07, 2010 | Computers & Internet
The notebook does not detect wireless networks and the wireless adapter is not detected in the device manager
You need to disconnect all the cables and the battery from the sys and press and hold down the power button for about 30 to 40 seconds than connect the adaptor and the other cables in and boot the sys to the BIOS screen and set theBIOS defaults.
Than check if the wireless button is blue or not or if the sys is connecting to the network.
If it doesnt than try going online trough the hard wire and download the latest drivers for the network adaptors and install them after that restart the sys.
After that if doesnt work out that means the mother board has gone bad as this series of laptop manufactured by HP has a recall on the motherboard and HP was providing a free repair for these. You must check with HP if the enhancement program is still active on your sys or not.
Feb 19, 2010 | HP Pavilion DV6449US Notebook
My belking keeps losing connection during games?
If your wireless you probably need to change broadcast channels on the router ( to the last channel) if its hard wired, you probably need to port forward the ip address for the Xbox
Oct 05, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Cannot connect anymore
Does the router work with the wired port connection? It's entirely possible that the router just went belly-up on you ...Linksys is an awesome brand, but sometimes it happens.
If the wired part works, the wireless transmitter inside may have gone bad. Best to just get a new one for about $50 ...but keep the old one in case you need a wired connection somewhere else around the house :)
Sep 28, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Connection trouble
I purchased linksys WRT54G when I connect the second wiring I
lose my internet. My wireless use to work but since I disconneted it and reconnected the wireless does not work.
Jul 11, 2008 | Linksys Wireless-G WRT54G Router
Linksys keeps disconnecting
Have you tried different ports on the router? If so have you tried other computers hard wired in? Hard wire in one of your laptops for awhile and see if they lose connection as well. If so then the problem is the router, but if they can stay connected then I would try either updating your network card drivers or getting a new network card perhaps. Let me know if that helps any.
Sep 25, 2007 | Linksys Wireless-G Broadband Router
Toshiba Satellite A105-S4384 Notebook Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
