Question about Samsung SCX-4725FN All-In-One Laser Printer
I got problem with printer samsung scx4725, one part need to be replace is pick up roller, and next to it 2 plastic tab, oneis one missing. Pls tell me where can I download part. Thanks a lot!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
Try to clean the roller with alcohol first; it worked for me with the SCX4521-F and If you have already done it, search through google (sorry I don't know your'e region)
good luck
Posted on Nov 06, 2010
How to install picker on samsung printer
By replacing your pickup roller, you see that is surrounded by a white base, this base has a safe at the sides that you need to do is pull them to the sides, but at the sametime, then you pick up roller is released from the plastic part, then you can put your new roller.
Apr 23, 2012 | Samsung ML-2510 Laser Printer
How to remove and replace a printer roller on HP Laserjet p3005
Hi Adam,
I suspect that you are talking about the tray 2 pick up roller. Here are the directions for that:
1.)Remove paper tray
2.)Unlock left locking tab and rotate forward untill bushing slides off
3.)Remove black plastic roller retaining bracket
4.)Slide roller to the left untill right side of shaft clears the bushing
5.)Lift roller out of printer
6.)Place spring loaded end of roller shaft into left housing
7.)Slide roller to the right and rotate until roller locks into pickup shaft
8.)Reinstall black plastic roller retaining bracket. Left side first.
9.)Reinstall left bushing and lock into place
Let me know if you where sucessfull,
Printer Piete
www.allprotech.com
Dec 28, 2010 | HP LaserJet P3005 Printer
My printer pulls multiple sheets at once.
yo have to:
1. Clear paper pick up roller whit wet cloth or alcohol
2. Clear separation pad (located under pick up roller) using same way as pick up roller.
Good luck
Jun 18, 2010 | Samsung ML 2010 Laser Printer
What is the procedure for replacing the paper feed roller on a canon ic mf5750?
1) If you want to replace roller that picks up from cass. you need to remove toner cart. and pull it out it has from each sides an plastic holder
2) from ADF pls. call the service
Jan 12, 2010 | Canon Office Equipment & Supplies
Xerox Workcentre PE220 doesn't load paper. Stopped loading paper, and I found a torn rubber ring inside. I found where it was, but can't figure how to replace it.
It sounds like you need to replace your paper pick roller. It is held on the shaft by some white plastic clips. You can pry the tabs up and slide them to the side, then rotate and drop out the pick roller assembly. You'll need to find a source for that part.
Jul 06, 2009 | Xerox WorkCentre 220 All-In-One Laser...
My canon pixma ip1700 eats all my paper in printing just one page
rubber roller is worn
while the paper load, it is a roller (made of silicon i think) take the job to pull inside the printing mechanic.
there are 2 roller in opposite wich responsible. the upper roller (big one) and lower roller.
to fix ur printer, u must open the casing. note! there are 6 point for plastic snaps (2 low-front, 2 side, 2 back) and 2 screws.
fyuh... now there is ur decission. 1. disassemble the mechanic to take those 2 rollers or 2. let it watch :p
surely this far u must pick 1st option. sorry if i cant pictures the process, 'cause this to me in indonesia called gampang yang disusahin. once do succeed, u dont want to do it again. man so tired with ur eyes.
1. dismount the metal mechanic. there are about 6 to chassis and 1 to main board (u can see the clear). but becareful to the mechanic parts, usualy the springs.
2. now u can get the big roller.
3. release the roller ruber.
4. cover the plastic part of the roller, rounds with 2-3 layers (what u think enough) with rubber tape. this rubber tape usualy to isolate open cable. electrician tool.
5. then put the roller rubber back to plastic.
...this is the hard one. sorry if i can tell the detail, cause my english bad :p
6. (think) u must also take the lower roller. and do the same as the upper roller. becarefull, cause once u missed pulled out the rubber, u might ripped it. then u must replace all the rubber with tape till same thickness, and note for the direction of paper flow. and also note that, dont put rubber tape too thick for lower roller, it might stuck and u must disassemble the printer again.
7. assemble the printer again.
8. the u can now print hundreds while u're left it sleeping.
hehe... next time i'll post the picture. damn, i hate do the repair, now i have to post pictures? c'mon :p
but i promise, if people here finding hard to understand my story. i'll post pictures.
am also did the the job for my ip4500. man... it hurts my back altough my tears drop when i see them prints thousand of paper without pause :D
c ya letta...
u can call me at +628886696663 (expensive international call). if am the one who got trouble. i'll choose wait to see pictures.
Gbu.......................
May 02, 2009 | Canon PIXMA iP1700 InkJet Photo Printer
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Samsung ML-2010 won't feed paper
This is a step-by-step process for replacing the tire (roller). Thanks to dizzyzuma for helping me get the right part and get the procedure down.
1: You will need to manually shut off the printer in the middle of printing in order to release the tabs. Put in a few sheets of junk paper and print a few blank documents. You want to shut off the printer using the switch in the back when the roller is approximately in this position:
2: Hold the down the two side tabs that are locking the tire into place and press down on the tire with your finger. It should pop off relatively easily.
3: Turn the printer back on. The tire will rotate around to its starting position, but it will now be unlocked. Turn the printer back off.
4: Rotate the tire towards you and unhook the two bottom hinges. It should come off without much force.
5: Replace the old tire with the new tire.
6: Re-insert the tire onto one of the bottom hinges and rotate it around so that both of the bottom hinges (tabs) are in.
7: While holding the back of the metal bar with your fingers for leverage, press firmly with your thumb to snap the tire back into place.
8: Turn back on the print. You’re good to go.
Mar 15, 2008 | Samsung ML 2010 Laser Printer
Print is missing off top of page
What application are you using (w/ the document)? Margins sound like the problem. If you have changed any bottom or top margin, or added a footer or header, it may have altered the overall option on top of page.
Dec 18, 2007 | Samsung CLP 300 Laser Printer
Samsung SCX-4725FN All-In-One Laser Printer Logo
67 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
