Question about Sony Handycam CCD-TR96 Camcorder
I have a Sony Handycam CCD-TR96. It worked fine the last time it was used, but when I got it out again it's completely dead. It won't even hint at doing anything with either a charged battery or the A/C adapter. I checked the voltage from the A/C adapter, which is about 7.1 Volts; and the connections appear to meet up fine. Is there an internal fuse or something that could be blown? Any suggestions? BTW, there's a tape stuck in the recorder that I cannot eject since there's no power. Thanks.
  • 196 Answers
SOURCE: PLEASE HELP!! Sony Handycam CCD-TRV37
The problem is usually caused by no drum rotation. Have it serviced.
Posted on Feb 13, 2006
larry james
  • 287 Answers
SOURCE: no power Sony Handycam Model CCD-FX620
there are fuses ,but they are small solder in types, all fx series camcorder have a common problem with the rear power board working it's way loose and unplugging itself from the main board. these units have alot of solder connection issue due to sony's use of poor solder back in the earily 90's
Posted on Sep 16, 2007
SOURCE: Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Posted on Oct 21, 2008
satavlad
  • 405 Answers
SOURCE: Sony Handycam CCD-TR64 cassette door won't close
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Posted on Dec 04, 2009
Testimonial: "Thanks. We ended up getting a new camcorder. That Handycam was as old as I am (18 years), so it was time for an upgrade anyway."
Davidivory1
  • 338 Answers
SOURCE: Sony CCD-TVR-16 Handycam tape keeps ejecting and
You should remove the tape, check it is not full up, or replace it with new tape, I had this problem weeks ago, turned out the write-protect tab on tape had got pushed over to prevent recording.
Posted on May 21, 2010
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
I have a Sony Handycam CCD-TR61. It has worked fine until today. It will not accept a tape. If I close the door without a tape it closes and completely shuts like it is supposed to. But if I put in a tape...
Many times it's a belt slipping. Since the tape isn't pulled into position, it's rewound and the tape ejected. A damaged or mal-adjusted switch could cause this too. The most you can do is blow it out with compressed air to see if that helps. I doubt there are many thing the end user could do.
Oct 29, 2017 | Sony Handycam CCD-TR618E Camcorder
Handycam CCD-TR618E Hi-8 Analog Camcorder: I have a Sony Handycam CCD-TR61. It has worked fin...
that is look to be the cassette in switch
located on the side of the cass housing
or a sensor ...
hope that will help and this kind of trouble
is easy to fix for experienced tech an hour max
hope you will find one
regards Alan
May 18, 2010 | Sony Handycam CCD-TR618E Camcorder
Tape door will not stay closed. shut tape compartment door...runs for 3 seconds...reopens.
It is possible on the CAM mode the tape reached to the end, or this is
typecal problem from Sony the sensor it detecting 2 reels to turning the tape were faulty.It require to replace the cassette compartment or it call LS chassis assy. It will cost about $200, $250 in Australia to repair it
Jan 08, 2010 | Sony Handycam CCD-TR96 Camcorder
Where is the power plug in at
just under the battery, its a small rectangle connector
Sep 24, 2009 | Sony Handycam CCD-TR96 Camcorder
Lcd screen is blurry on my sony handycam dcr-hc20
This does not sound like a CCD problem yet, but a LCD problem. This would require you to replace the LCD screen. Sounds like the LCD inverter is shot. That is the power supply that is required to back light your LCD.
Before we blame that, you should make sure that all ribbon cables are secure and tight.
Good luck !
Feb 04, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Black screen
It is known problem of bad ccd imager in camcorder and requires replacement of that part.
Sony will repair CCD-TRV318 Free of Cost in ccd imager problem.
Please click Sony CCD Imager Support for details.
Good luck.
Feb 01, 2009 | Sony Handycam CCD-TRV318 Camcorder
Thanks for the info.
thats great. enjoy your day.
Jun 15, 2008 | Sony Handycam CCD-TR96 Camcorder
Date and time won't save
Back-up battery is weak, replace it with new one. its small coin size battery inside a cover some where in ur camera. find it n replace it.
Jun 14, 2008 | Sony Handycam CCD-TR96 Camcorder
Records sound but no picture
there are two possible problem of your camera...one check the iris of the camera if it is opening,you will see it went you look inside the lens when you turn on camera mode....and if you see that the iris is opening...the second may be the ccd image sensor......if that is the problem you have no choice but to go the sony service for replacing the ccd image sensor...
Sep 03, 2006 | Sony Handycam CCD-TRV37 Camcorder
Video Cameras Logo
Top Sony Video Cameras Experts
Parshiv Luthra
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
