Question about Epson Stylus NX400 InkJet Printer
My Epson stylus NX 400 continually says "error..replace ink cartridges" I did and nothing changed.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
Assuming the cartridges are new (since almost all of them have a chip on them)
1. Make sure you match color of cartridge with the correct slot. If same error, then
2. remove all carts. and clean both cartridge holder and cartridge contacts with alcohol.
good luck
Posted on Nov 06, 2010
Epson Stylus NX 125/127 Series Both power light and ink light flashing not recognizing two cartiages
Power light flashing : processing. Ink light flashing : not recognizing cartridge. Replace the cartridges.
Feb 17, 2013 | Epson Stylus Multifunction Inkjet Printer/...
How do i replace the ink cartridge on an epson stylus nx 400
to replace ink before they run out..
You can view on-screen instructions for replacing an ink cartridge using the printer maintenance utilities.,click the button on the Maintenance tab. then select Ink Cart Replacement and follow the instruction from there on.
Jun 27, 2010 | Epson Stylus NX400 InkJet Printer
How do you change ink cartridges on Epson nx 400
Please download the user manual by clicking HERE.
Open the document which I uploaded for you and go to page 33 to see the procedures of replacing ink cartridges.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
May 06, 2010 | Epson Stylus NX400 InkJet Printer
New cartridges won't install.
unplug your printer. then remove the cartridges and reinstall them being sure to seat each one firmly into it's socket. finally plug the printer back in.
Aug 17, 2009 | Epson Stylus NX400 InkJet Printer
My Epson Stylus NX 400 is not printing.
no it cannot. Those multi-colored cartridge system requires that you put in every single color, AND ensure that they are not empty before they will print. Even if all you want is a black and white copy.
Apr 28, 2009 | Epson Stylus NX400 InkJet Printer
My Epson NX 400 will not recognize my ink cartridge replacement.
Maybe caused by a bad cartridge or a bad printhead, unfortunately.
Please reseat the cartridges. make sure that you are using correct genuine epson cartridges.
Contact epson to receive free cartridge replacements as a one time courtesy to isolate the issue.
Apr 25, 2009 | Epson Stylus NX400 InkJet Printer
My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
White lines on printed photos Epson Stylus NX400
You need to clean the print head on the cartridges , please follow these steps\
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Mar 15, 2009 | Epson Stylus NX400 InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus NX400 InkJet Printer Logo
311 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
