Question about Microsoft Xbox 360 Console
Xbox 360 3 red lights problem
When I turn my xbox on 3 red lights apear.
What can I do to fix it?
  • 106 Answers
I believe this is related to the GPU (graphics processor unit). I think the only cheap fix is to take apart the unit, use a heat gun and lightly go over the board. This has worked for me about a year ago.
Posted on Jun 15, 2008
I have an xbox360 I had almost a year I went to switch it onan a red light apear and tells me to go to xbox custemer care E37
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 21, 2011 | Microsoft Xbox Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
I droped my xbox on the floor
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console is well ventilated by making sure that the console is not in an enclosed space. You may hear the fans operating.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
Sep 01, 2009 | Microsoft Xbox 360 Console
Xbobx 360 3 red lights
3 Red lights problem is a drawback of Microsoft Xbox 360
Check out the blog post at http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/ to know more information on fixing your xbox
Jan 07, 2009 | Microsoft Xbox 360 Console
X Box 360
It might be Red ring of Death problem, You can either send your Xbox toMicrosoft and wait for 2-3 weeks till you get back your Xbox or you canfix the problem yourself with the help of a DIY fix guide.
Check out the post discussing about RROD problem here: http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/
Hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
3 red lights and one green one in the middle HELP
how can i fix this ring of death it will not let me play the game
Jul 31, 2008 | Microsoft Xbox 360 Console
3 light
You can easily fix your XBOX 360 - With The Official XBox 360 Repair Guide from www.3RedLightFix.com
Fix your XBOX 360 in less than 1 hour with an XBOX 360 Repair guide from www.3RedLightFix.com.
Apr 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
