Question about Hayward Navigator Pool Cleaner
My Navigator stopped working---it just sits there. I replaced the foot pads---still nothing!!
  • 366 Answers
If you have enough suction and it still does nothing, even after replacing the shoes, it probably needs a turbine kit with "a" frames. if the bearings are bad on the turbine or a - frames, it won't let it achieve enough range of motion to actually move the unit. I would recommend installing a turbine kit, with a-frames. hope this helps.
Posted on Nov 08, 2010
  • Ernie Sparks Apr 27, 2013
    I have the same problem. Changed EVERYTHING including bearings, turbine , shoe pads, "Y" rocker framesw and bearings. Still does not work. Has great suction at the hose where it connects to the Navigator but only a limited amount of suction where the water should be entering the opening at the bottom. Very little suction there and the turbine turns when I hold it just under the surface and tap it with my finger but it still turns very slowly. I've covered all the vents on the exterior of the unit with duct tape but still cannot get adequate water flow over the turbine. Where coule the water possibly be entering to bypass the turbine?
2008 navigator, which has had a slow leak for a while...back would be low if it sat unused for more than a day. It would air up and then be ok and hold. Last week, started not holding air.
It is a brisk market... (AIR-BAGS)...
I am going to post ROCKAUTO EXAMPLES...
but by all means check out eBay & Amazon prices
as a competitive pricing .
I HATE to say it... but there are other reasons
for air-loss failure... and if you can stop by the
VARIETY store and buy some BUBBLE solution
or put soap into a spray bottle...
System AIR LEAKS should be pretty easy to find.
Amazon com Gazillion 2 Liters Bubble Solution Toys Games
air bag
Amazon com A1 Cardone 4J 1014A Remanufactured Suspension Air Spring...
REPAIR UNION
http://www.rockauto.com/en/catalog/lincoln,2008,navigator,5.4l+v8,1440979,suspension,air+suspension+line+repair+union,1001779
REPAIR DATA
More Information for DORMAN 949210
http://www.rockauto.com/en/catalog/lincoln,2008,navigator,5.4l+v8,1440979,suspension,air+spring,15005
Jul 10, 2017 | Lincoln Navigator Cars & Trucks
My 2007 Chevy Aveo stalls at lights and stop signs. I had the 2 sensors related to the timing replaced, the throttle box replaced, and a new coil, all in the past month, but nothing has changed.
a simple test here is to idle the car, and put your foot on the brake
if it stalls then the problem is a faulty brake booster
every body sits at lights /stop signs with their foot on the brake not realizing it and miss that bit of evidence in determining a problem
check for vacuum leaks ( transmission actuator hose, vent controls) run fault codes to see if there are problem sensors
Nov 29, 2016 | Chevrolet Aveo Cars & Trucks
Problem with brake sensor on navigator
The brake pad sensors identify how many revolutions the tire makes before coming to a complete stop, based on how hard you press on the brake. Most cars are equipped with two brake pad sensors: the rear and the front.---------------------------------------------------------------------------------
Car Diagnostic Tools
Nov 24, 2012 | 2005 Lincoln Navigator
Our navigator stop working. Is there a complete rebuild kit for it?
When I tune-up a Navigator I usually replace the wings, flags, pads, pods, turbine and A-frame. Some of those are kits but i don't think you can buy just one kit that does it all.
www.cpo2go.com
Aug 10, 2010 | Hayward Navigator Pool Cleaner
The Hayward Navigator pool sweep does not move. The pressure is 7.5, the suction seems to be okay, and the "flippers" move, but the pool sweep just sits there.
You may need to replace the pads on the flippers. You can get new 'feet' for your cleaner at any dealer . They just pull off and press on, They go on only one way so check the tabs before you press them on.
Please Vote !
Jun 06, 2010 | Hayward Navigator Pool Cleaner
Rubbing noise from rear passenger side of an 03 navigator
I would guess it is a brake pad that is a little slow releasing sometimes.
Jan 30, 2010 | 2003 Lincoln Navigator
The brake pad ,is coming out of the assmbly
time to replace the pads, replace either both front or both rear pads. while you have the pads off, inspect the rotors for even wear.
Nov 01, 2009 | 2009 Lincoln Navigator L
Pulsating breaks
Who else drives this car? Going fast and quick stopping, riding the brake will get the rotors very hot. When they are very hot and you stop and sit with your foot heavy on the brake this will squeeze the rotor at one spot, as hot metal under pressure will bend and distort. This will result in the problem you are having.
Jun 30, 2009 | 2002 Cadillac Deville
03 lin nav wont go into gear after being towed
who towed it was there a towing sequence eg take a fuse out ect like some other cars
May 29, 2009 | 2003 Lincoln Navigator
Hayward Navigator Pool Cleaner Logo
971 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
