Question about Sunbeam 2350 Heritage Series Mixer
How do I disassemble the beater end of the Sunbeam 2350 (without breaking it)?
  • rantcliff Nov 06, 2010
    OK, so I broke it, but figured it out :/
    You have to remove the first of the two little screws next to the beater shafts then there is a little screw that is accessed by removing the release button. You have to pry up the button and then there is a screw at the bottom of the hole.
    Anyway after doing all of this, you still have to remove the whole rear end and wiring to get the business end out. Then the business end is a pretty sealed unit (which can be accessed with prying). All this to see that the plastic gears were indeed worn down and the reason the system was slipping.
    I had already bought a replacement, just wanted to make sure my diagnosis was correct.
4 Suggested Answers
  • 44 Answers
SOURCE: Where can I find the Manual for Sunbeam Model 2350 350
http://www.sunbeam.com/ca/category.aspx?section=kitchen&cid=14
Posted on Sep 08, 2009
SOURCE: Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Posted on Dec 13, 2009
whlyon42373
  • 71 Answers
SOURCE: Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Posted on Dec 15, 2009
Testimonial: "I will try the rubber bands the next time I use the mixer - Thank you"
How to disassemble mixmaster heritage series model 2351
try the following sites
www.eserviceinfo.com/equipment_type/model###
www.freeproductmanual.com/manufactures_name/model###
www.info.com/manuals
www.s-manuals.com/manufactures_name/model###
at the browser type the following information
sunbeam disassemble procedures for make/model ###
you could look at www.youtube.com/disassembling mixmaster model 2351
Mar 31, 2015 | Sunbeam Food Mixers
Will not spin fast enough to whip cream
Do you have more than one size beaters, if you do use the smalest ones that will rase the rpm DFD
Apr 12, 2009 | Sunbeam 2350 Stand Mixer
Motor runs but beaters do not turn.
I challenge you to do-it-yourself...you can do it. Just be careful when removing it apart. I advise you to take a video or get some snap shots while you are at it. This way, if some springs snaps out, I assume that you took a picture of it already.
Usually those plastic gears are the problem. Goodluck!
Jan 13, 2009 | Sunbeam 2350 Stand Mixer
Nov 23, 2008 | Sunbeam 2350 Heritage Series Mixer
Have one that does not work and want to know how to open it- can see no clear idea how to and want to avoid damage. regards, Peter
The mixer is not designed to be disassembled or serviced. When it breaks (and it will) Sunbeam will replace it under warranty if you are lucky or you toss it in the trash.
That said, start by prying out the beater release button. There are two small screws under it and one between the beater inserts to remove the chrome front cover. The large black dial at the rear can be pulled straight off, revealing more screws. The motor and drive assembly in the top cannot be removed without disconnecting wiring from the circuit board in the base.
Jul 27, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam Stand Mixer
For whatever reason, Sunbeam must have decided to cut on costs and used a plastic gear to transfer power to the beater. I had my Sunbeam for two years and the plastic gear decided to break. End of mixer. You cannot find a replacement part anywhere. It is the last sunbeam I will buy.
Dec 02, 2007 | Sunbeam 2350 Heritage Series Mixer
Sunbeam 2350 Heritage Series Mixer Logo
1,006 people viewed this question
Top Sunbeam Food Mixers Experts
Vincent_G
Vincent_G
Bruce Showalter
Jerry Greenberg
Jerry Greenberg
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
