Question about HP Photosmart C5580 All-In-One InkJet Printer
Will not print says alinment is off.each time it trys to print it it goes real slow;then says alinment poblem.this problem started after we went from dial to hughes net satalite.
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
1983 s10 blazer low rough idle and trys to die when starting have to give it a little gas and put it into drive real quick then when slowing down keep foot on gas pedal as i also slow down with break pedal
Could be several things, a vac leak, dirty throttle body, or faulty idle air control valve.
The computer controls idle speed by how much air enters the throttle body thru the valve.
Usually a vac leak would speed up the engine unless it is causing the rough idle.
Jan 10, 2013 | Cars & Trucks
My craftsman 25hp 48 backs up real slow
what i find is the rod goes out of adjustment causing the valve to not open fully if you have the one lever on the fender it will be a little easier than the pedal style put adjust the rods a little at a time it just takes a time to get it right
Jun 15, 2012 | Craftsman Garden
Printer starts printing real slow after around 20 prints
this problem will be fixed by changing the fuser. the thermistor has been comprimized. the reason the printer slows down is the regulation of the heat has slowed and the fuser is not heating fast enough to keep up with the demand. changing just thethermistor woulld fix it
Apr 22, 2010 | Lexmark T630 Laser Printer
Prints test page every time i switch on
you have to print test page then alin the page up withthe bars and letters, you have to do this each time you put in a new cartridge, use he menu key to aline the keys.
Jan 13, 2010 | HP PSC 1510 All-In-One InkJet Printer
Not printing. Will not take in the printing paper. Information window tells me to aline the ink cartrage. I have replaced new ink cartrages. Somthing is trying to turn as it is making a ratchet noise. ...
yes you have to print out a alinement sheet then put it in the scanner and scan then follow the directions to aline the print cartrigde once it is alined you ready to go. and you have to do this each time you replace the cartridges.
Oct 07, 2009 | HP PSC 2175 All-In-One InkJet Printer
HP 1315 printing real slow
If there are a compatiable black cartridge
replace this cartridge with your old empty cartridge and print a test page (don't mind about printing of black )
If speed is correct,
then replace the black cartridge with another new cartridge.
(some time compatiable black cartridge not work properly to flow ink)
Jun 04, 2009 | HP PSC 1315 All-In-One InkJet Printer
Ink in blue slot is not dissolving
If your printer still can print but with no cyan color then you most likely have a bad printhed. If your cyan ink is not melting it's because it is not using any ink . Get into the "print quality" menu and print the test page. If you get black, yellow, and magenta but little or no cyan then your printhead is bad. Whith these machines cyan is the first color to have poblems starting with weak or missing jets.
You can try to run the "eliminate light stripes" to see if it will help.
Run it about 3 to 5 times. If still not working right, turn the printer off for at least 4 hours and then test again.
Hope this helps,
Dan
Oct 28, 2008 | Xerox Phaser 8500/DN Printer
All 4 power windows on 1999 Chevy S-10 Blazer started moving slow and then stopped working.
they have a relay for the windows i would start there check with dealer for location or your parts store as they are located all different places
Oct 26, 2008 | 1999 Chevrolet Blazer
HP Photosmart C5580 All-In-One InkJet Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
