Question about Whirlpool Duet GHW9150P Front Load Washer
Water does not drain fully from tub. Pump is working...or seems to be. Could it be a plugged drain issue?
  • Whirlpool Master
  • 8,220 Answers
Have you tried this: Get a 1/4th inch nutdriver and remove the service panelwater does not drain fully - themobilian_58.jpgthemobilian_59.jpgthemobilian_60.jpg
Posted on Nov 06, 2010
  • Thomas Heay
    Thomas Heay Aug 13, 2014
    I'll try that. Why is the tub so loose and what can be done?
How do I fix PE Error code for LG Washing machine fuzzy logic
PE means pressure error. The water pressure sensor is reporting too much water in tub. It can be bad sensor or too much water is really in the tub. Too much water is caused by water not being pumped out. Kinked line. Bad pump. Etc. or inlet valve not shutting off. Does it seem that there is too much water in tub? If water level seems good and if tub fully drains, the water pressure sensor probably. Good luck.
Mar 03, 2015 | LG Washing Machines
We have Kitchenaid Dishwasher KUDP02FRSS1 that does not drain water fully after the normal wash + heat dry cycle. There is about 1 inch of standing water at the bottom of the tub. Pressing Cancel button in...
The situation is most likely linked to the previous cycle not being completed when you press the Cancel button. Most likely the controller is not timing correctly or the water is not heating enough.
Are the dishes hot at the end of the dry cycle?
Sep 13, 2011 | Dishwashers
Drain doesn't seem to work. If there is water in the machine when you start it up, it just sits there humming slightly. If you drain all the water it starts refilling- but still pump won't drain...
Hello. If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Apr 11, 2010 | Washing Machines
Had a LD error and successfully cleared clog in waste water tank. Turned it on and pump worked perfectly to pump out water. Started a new cycle to test everything and things went wrong. First, the tub...
If the water keeps filling with the unit unplugged you have a bad water valve(or low house pressure)
If the unit does stop filling when unplugged you have a plugged pressure hose to the pressure switch or a bad pressure switch. To access you peel back the front emblem to remove a screw in the center. This allows you to raise the top to check the pressure hose. You can also find the end of the hose at the control panel to blow through it, should be clear when tub is empty of water. A hole in the pressure hose would also cause flooding. This hose connects from the bottom of the outer tub to the pressure switch in the console to control the water level in the tub. Unit will not turn on drain pump if it does not sense water in the tub......
good luck......
Apr 06, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer doesn't fully drain
Hello. Yes this is completely normal. Lots of people have this and they too think something is wrong. As long as there isn't water in the tub.
Here is a website for you to copy and paste into your address bar:
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm/printable
I think you will find this very knowledgeable!!!! Thank You
Aug 29, 2009 | Kenmore 22422 Top Load Washer
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Dishwashing machine not fully draining (2 inches of water remain). I have an open problem concerning this problem. I have a new pump. dishwashing machine not fully draining (2 inches of water remain) For...
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Apr 19, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Cloths are still very heavy and wet
Sounds like a pump problem or a kinked drain hose. The machine cannot spin or spin properly until the pumps gets the water out of the tub.
Sometimes the drain hose get plugged or kinked and won't allow the water to be pumped out so make sure that is not an issue. But, I'm more inclined to believe this is a pump problem.
Dec 30, 2007 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
297 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
