Question about Freezers
I have an old Ben Hur chest freezer that's still working good. It's so big, we put a cow and pig in it. I need to replace the gasket on the door. Any ideas?
  • Freezers Master
  • 1,150 Answers
There are several refrigeration houses that can have gaskets custom made to your spect. I would call Rick at Restaurant Parts and More and see if he can help. 1-888-814-1110.
If you have a model and serial numbers, this may also help as he does have access to some manufacturers for OEM parts.
Posted on Dec 10, 2010
Why is my Hoover A Class upright freezer alarm light constantly on
1) It could be a short. 2) The thermo sensor that turns the light on could be defective and needs to be replaced.
Mar 24, 2015 | Hoover 9.9 cu. ft. / 280 liter Upright...
How to fix a chest freezer seal
Hello friend, I appreciate your post!
I see you are trying to fix the seal on your Frigidaire chest freezer. Are you having an issue with your freezer not closing? If so, have you verified that there is nothing blocking the door from closing as well as making sure there was nothing between the door gasket and the freezer body? Next, I would check to make sure that the gasket is not damaged or compromised in any way. If it is not damaged, I suggest contacting your local authorized technician for further assistance. I hope this information helps. -Matt
Jul 22, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
How tight should the suction be on the door of chest freezer
Hello dotty26 - The door gasket should be securely closing with no resistance. You may try lubricating the door gasket with petroleum jelly to make it easier to open as well.
Feb 25, 2013 | Frigidaire 5 cu. ft. / 142 liter Chest...
Chest type freezer Model # TCF1510EW00 Needs a gasket around the door. Where can I get one? Is a Whirlpool Estate chest freezer; serial # EWF1793518 with a date of 090604 stamped on the metal tag.
The part number for that gasket is 4346693 it could be purchased at your local appliance parts store or online at;
apdepot.com
searspartsdirect.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 14, 2011 | Whirlpool Freezers
We have a 20 cu ft GE chest freezer that will only cool to 20 degrees. What can I check to determine how to fix it?
Please check : - Your door ( gasket /seals, small air leaks) - Refrigerant level - Temperature sensor for failed
Regards,
Dec 04, 2010 | GE 19.7 cu. ft. / 558 liter Chest Freezer...
Stand up freezer builds up frost quickly
It sounds like you may be on the right track here. If the gasket is old, hard, and brittle, it will allow moisture to be administered into the freezer, causing frost buildup. Not to mention, that old door gasket is leaking out a lot of cold air. Your best bet is to provide the model number (as you've shown here) and the serial number to an appliance parts store or authorized GE appliance parts outlet. They should be able to provide you with a brand new gasket. Removal and re-installation of the new gasket is fairly simple and you'll notice a big difference, not only in the lack of frost buildup on the inside of the freezer (especially in the summer) but you may even see a noted improvement on your electric bill as well!
I hope this helps and let me know if you need any further assistance! :)
Sep 22, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
The front surface of the chest freezer is
Hi, can you put your hands on front of freezer, and check from 1 to 5 without getting burn? how long can you keep your hands on front of freezer? check from 1 to 20 and let me know, normally there's a condensate line, or part of condenser lines that passes through freezer body , purpose of those condensate line is to prevent your door gasket from freezing , especially during winter. It's normal for front of freezer to be warmed, on hot days it will be a little hotter, you said "very hot" makes me wonder how hot it is, put your hands on front of freezer, use number method and let me know, but it's normal. good luck.
Aug 19, 2009 | Kenmore 5 cu. ft. / 142 liter Chest...
Chest freezer lid repair
if your freezer has the sping etc in each of the hinges, then yes take them off. If your freezer has a torshon bar type spring, DO NOT take the hinges off, as you will not get it back together
i have always replaced liners with the door attached. The lid of the freezer is going to bow out of shape when you remove all the screws and take the old lining off, so you need to replace the lining and leave the screws loose so you can realine the door bit by bit.
it is a bastard of a job, and i wish you all the best.
May 01, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Frigidaire Chest Freezer Door Insulation smells like fish
might sound stupid but take the cover off the compressor electrics and make sure no plastic is overheating.
Oct 08, 2008 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezers Logo
379 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
