Question about Roper REX4634KQ Electric Dryer
My dryer will only work on one spot on the knob and will shut off alot and I have to tap on the knob to get it going again.
    President:
  • 3,074 Answers
I am assuming that it is the timer motor, here is a website that will tell you how to test it, hope this helps Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Posted on Nov 06, 2010
Igniter works, changed coils but flame will not come on unless on tap on valve. After the flame shuts back off it will not come on again unless I tap on the valve
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 15, 2011 | Dryers
It will not automatically turn off when running, the knob does not turn while running.
Miss Stephanie you must replace the timer.
If you have a timed dry setting. Run timed dry. If it does not shut off timer is bad.
If it does shut off you have a sensor problem.
Apr 14, 2009 | Kenmore Dryers
Auto Dry not advancing
It sounds like a timer problem since it happens during timed also. Some dryers don't have an actual moisture sensor for auto dry. They work by knowing that as long as the clothes are wet the temp won't go past a certain point. As the clothes dry it trips a thermostat that lets the timer advance. Until this is fixed DON"T trust the timer to shut off the dryer. Sometimes it won't or could leave the dryer running for hours. This has nothing whatsoever to do with fuses. There are no fuses in a dryer. Just high limit thermostats and other devices that will shut off the heat but usually not the motor.
May 30, 2008 | Kenmore 73952 Gas Dryer
Drum will not turn
From your description, you may have a bad spot in the armature of the motor, or a faulty centrifugal switch on the motor.
May 24, 2008 | Dryers
Stops during cycle
Maybe. Will the unit restart in the same position or do you have to move it? If it will work in the same position and all you're doing is waiting for a bit of cooldown...it could be a defective high limit switch that is resetting. If it will restart only after you move the timer, then change out the timer. This is a bit of a mystery since timers generally don't have 'dead spots'...they are designed differently than that.
Dec 24, 2007 | Kenmore 64902 Electric Dryer
Roper REX4634KQ Electric Dryer Logo
48 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
