Question about Intertherm Heating & Cooling
I have an Intertherm furnace that now will not turn on....Its a gas unit..electronic ignition,,, and from what I could read on the furnace..the model number is G2RR050C12...geez..I hope thats correct.... The landlord tells me..its just a clogged filter...sighhh....I cant even find access to the filter!!!....HELP!!! Any help in this area..needless to say..would be much appreciated
    Problem Solver:
  • 16 Answers
The filter is in the bottom of the furnace. Turn T-stat off and go to furnace. Unplug furnace. Top door comes off first, pull up on top door then out and down, set aside. Bottom door lifts up and then out. There is ur filter at the bottom. azeddysac@yahoo.com change ur filter then hit me back
Posted on Nov 06, 2010
Furnace ignites, fan runs but no output to vents. Does it have an dampener? Internal
If you are positive the fan is turning and no air flow you have a very dirty filter or all zone dampers are closed (very unlikely because most zone dampers fail in open position).
Jan 06, 2016 | Intertherm 56000 Btu Gas Furnace
Intertherm gas furnace in mobile home..igniter comes on then nothing tries to fire byrners but nothing
by igniter I assume you mean the thermocoupler. are you turning the control button to run after you light the pilot light? Normally when those furnaces quit it is the thermocoupler that has quit. Get a new one and leave it in the furnace compartment as a spare.
Jan 06, 2015 | Intertherm Heating & Cooling
INTERTHERM NO HEAT OR BLOWER
This could be failure of the igniter and/or thermocouple.
Jan 27, 2014 | Intertherm 56000 Btu Gas Furnace
How do I light an Intertherm furnace Model Number MG 068A?
Hello, if the Furnace is a standing pilot then turn the knob on the gas valve to pilot, you will hear a hissing sound then use a match or a lighter to light it at the thermoouple. Hold the knob on pilot for about 30 seconds and then turn the knob to gas and burners should ignite.
Nov 11, 2011 | Heating & Cooling
Just replaced pressure switch on intertherm m1mb gas furnace but still codes "pressure switch open"
CHECK FLUE FOR OBSTUCTIONS AS WELL AS COMBUSTION AIR INTAKE FIRST. THEN CHECK TO SEE IF THE FURNACE DRAIN IS OPEN AND NOT CLOGGED [ONLY IF YOUR FURNACE IS A CONDENSATING HIGH EFFICIENCY MODEL, typically the flue pipe will be 2 or 3 inch pvc pipe] over the years more often than not, it is an obstruction or poor drainage which will not prove the pressure switch to allow the burner to ignite. in rare cases the furnace control board could be bad as well.TRY DISCONNECTING FLUE AND COMB. AIR AT FURNACE JUST TO SEE IF FURNACE WILL IGNITE. HOPE THIS HELPS!!!!!!
Oct 20, 2011 | Intertherm P3RA-048K Air Conditioner
When I turn on my furance or ac the blower is always on even though the fan is set to auto. When it is on heat it never gives off any hot air, so it never warms up the house. I had someone look at it and...
If this is a mobile home furnace they usually have a two stage gas valve. Generally they just have a delay in opening fully and are convertable from L.P to natural gas or vice versa. It is a possibilty that the gas valve is bad. If so it will have to be replaced. First I would have someone check your thermostat to see if that is what is causeing the blower to run . does the burner ever light? I wouldsuggest that you hire a service tech. who is knowledgable on intertherm furnaces. I don't recommend anyone who is not trained to change gas valves,because of safty concerns. I hope this helps you some. Thanks
Nov 12, 2010 | Intertherm Heating & Cooling
I have a Intertherm heating and air conditioner it is a Manufactured Home. The furnace model number is E2EB-017HA. When you flip the switch to heat and move the control arm up nothing happens. You can go...
When you turn the on/off switch to on you are turning on the "fan switch" and the blower motor is only coming on. When you turn the switch to cool and move the tempature control lever down you are turning on the air conditioner...So it sounds like your heater is not working. Is the heater electronic ignition or does it have a pilot? If it has a pilot the heater may not be working because the pilot is out and will need to be lit. If it is electronic ignition you will need to inspect the unit to determine what component is faulty. Could be the igniter,gas control valve,ect. Verify that gas is not shut off to unit at line valve and gas control valve on unit.
Oct 07, 2009 | Intertherm Heating & Cooling
Furnace blowing cold air
Hello , I think I can help , It sounds like the gas valve as long as your sure there is plenty of gas going to the unit and you have an electronic ignitor , if there is a pilot light its not electronic. the gas valve should come as an assembly to install and its pretty easy to complete. Let me know if you need more help. Good luck
Dec 22, 2008 | Intertherm P3RA-048K Air Conditioner
AC, but no heat
The clicking noise appears to be the igniter. Since it is not getting gas for some reason it will not operate and will shut down. This could be due to the burners being dirty or it could be a bad gas valve or it could be in the electronic mudule. Make sure there is gas coming into the home to the gas valve.Since you hear the igniter operating , for the time being we will assume it is ok. Clean the burners with a wire brush. Make sure they are clean. When reinstalling the burner. Make sure the igniter is directly over one of the burners in the path that the gas will take. This is important. Before attempting any repairs make sure you understand what to do and what not to do. Gas furnaces can be vary dangerous. If this is something you are not absolutely sure you can do. Get a qualified service man to repair and service the unit.You can get a qualified service man right here on this site for your area. I hope I have been of some help to you.
Nov 19, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
262 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
