Question about KitchenAid KBNS361TSS Propane Grill
Gas knob stuck on High - KitchenAid KBNS361TSS Propane Grill
  • 51 Answers
A crude solution is to unhook the gas. Take some WD 40 and spray on the knob. Use a pair of pliers to try to turn it with, but not hard enough to break it.
Posted on Nov 06, 2010
Weber Genesis Gas Grill won't heat up very high
yes the control knobs are what controls the heat, its a saftey thing on the bbq so turn off tank undo gas from tank open knobs release gas from line , turn off control knobs , reconnect gas line to tank ,turn on slowly , turn control knobs to on and light,
Jul 05, 2010 | Weber Genesis Silver B Grill
Pilot lites up but heater does not work even having knob on high
If the gas valve isnt opening, it will not allow gas ito the burner trays. Gas valve could be bad.
May 31, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
I have gas leaking out of the overflow, and it wont stop running out.... all the gas dripps till empty...need t o know if its the gas knob that wont cut the gas supply or if its the carb..
with tank empty and knob in the on position blow into tank air should flow turn knob to off position blow air should not flow . if knob passes lightly tap carb . the float might be stuck
Feb 21, 2010 | Cycling
Flame on my Whirlpool gas stove burners are too high on low
either turn down the gas knob or turn knobs to lowest setting without going out. That is about your only options
Aug 25, 2009 | Whirlpool SF367 Gas Kitchen Range
The ignitor sparking will not stop in after the
when you turn the knob or push a switch is going to the on posicion so that means that the switch is stuck in one of the knobs , you just have to see witch one is stuck
Jun 18, 2009 | Wolf Range 30 in. SCB30C Gas Cooktop
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Range burner will not turn off, the knob is tight and stuck
Not knowing age - very often older (standing pilot) ranges will have burner valves that become hard to operate. These are usually a tapered core valve that can be greased with a high temperature valve grease.
Jan 28, 2009 | Kitchen Ranges
My jenn Air gas cook top igniters started sparking on there own. I unplugged and left overnight but still have the same problem! Any ideals?
One of the switches that control the ignitor is stuck; you might remove the knobs to see if the switch actuators are visible without removing other panels and check to see if they can be operated by annoying them with an insulated probe such as a chopstick or wooden skewer. Ours are controlled by a cam that is part of the knob itself that passes an extension of the switch. The extension is visible with the knob removed.
Good thing you pulled the plug since the high voltage transformer that supplies the spark is definitely not designed for prolonged operation.
Oct 15, 2008 | Jenn-Air Kitchen Ranges
KitchenAid KBNS361TSS Propane Grill Logo
147 people viewed this question
Top KitchenAid Grilling Experts
Paul Carew
Paul Bade
Bill Boyd
Are you a KitchenAid Grilling Expert? Answer questions, earn points and help others
