Question about Zenith Televison & Video
Switch comes on but immediately goes off. The TV was made in 1990 but it still has a good picture whenever it works.
  • 476 Answers
Hello, This Zenith combination has the same power supply in common with the TV and VCR. The usual failure is in the VCR side, the loading belt starts loosening and it takes the timing adjustment out of whack, thus creating the momentary shutdown, until the TV is turned off and back on. It is not always the belts, some times the VCR just gets out of timing due to tape malfunction, drive clutch and or timing switch failure. The easiest thing to try, would be replacing the load belt(located to the Left side of the VCR assembly(as you are looking at the mechanism from the back of the TV with the back cover off. This is if you are willing to try this yourself and always considering safety rules(always unplug the electrical from the AC outlet). If you do not feel you can work on it yourself, a belt replacement should not cost more than 60 to 70 dollars. Hope this helps or feel free to ask any questions that you might have.
Posted on Nov 06, 2010
My TV brings up message "No Hard Disk Found" and doesn't show pictures
sounds like the hard drive went in the Digital TV box, call your local tv cable company for a replacement.
May 08, 2015 | Audio Players & Recorders
When I switch on my Samsung 40 in LCD TV, half of the pcicture comes inverted and after a minute or so, it straightens. Initially the picture is hazy and then the picture turns normal. Sometimes, the...
This problems could be also causes by the board the call the T-CON docoders board,it sit in at middle of the bottom of the LCD screen panel.Because this board decoders incomming pictture signal before it go into the LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoderd board for the replacement.
Apr 16, 2011 | Samsung LA40A450 40 in. LCD TV
Polaroid tv goes immediately off after turning on
Ur tv power supply board is defective.That the board where the a/c power cord go into it.Replaced the power supply board,ur tv will have stable power and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 27, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
32 INCH tv
the cpu of your tv is not working,coldsolder the mainboard of your tv and the cpu then get the voltage output of your tv.
May 27, 2008 | RCA 32F531T 32" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Hard Disk Problem
bad power supply from on and off so much change that out
are u on labtop tho then u may have to redo it may gotten bug run trendmicro.com see scan for bugs do windows upidate
Jan 26, 2008 | Microsoft Windows XP Media Center Edition...
MITSUBISHI VS-4543
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Oct 01, 2007 | Mitsubishi VS-4543 45" TV
WS-65807 picture goes black when using HiDef Signal
Tank, If the unit operates correctly on DVD then we can assume that the signal chain and display is operational. Can you substitute the Directv receiver to rule the box out as part of the problem? I know they came out and checked but how exhausting was the testing? Have you checked signal strength on the directv on screen setup? Low or marginal signal strength could cause intermittent blanking. When the screen goes dark does the audio continue? please let us know..
Jun 11, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
