Question about Sceptre X24WG-NAGA Monitor
Sceptre x24wg-naga keeps turning off. In the begining it would turn off shortly after turning it on for the first time that day. It would display the screen for a couple seconds then shut off, I did this four times each morning adnthen it would stay onfor the rest of the day. A month later it takes going through this ritual about 7 to 10 times and not in the middle of a game or surfing it shuts off. Is there a part I can replace and if so where can i get a schematic for this monitor? I haven't worked with elcetronics in 15 years.
budmrtn
  • 11361 Answers
SOURCE: Sceptre X22 Naga Will not power up.
Start looking at the power supply for bad caps, see some example of a couple yeras old monitors that failed due to cheap caps being used: http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 08, 2010
  • 109 Answers
SOURCE: X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
Posted on Jun 01, 2008
micromaster
  • 3614 Answers
SOURCE: Sceptre x9g naga v
May i know the exact detailed model/maker of your unit...?
Posted on Jun 13, 2008
SOURCE: Sceptre X9 monitor problem
hy,
usually the capacitors on the inverter board for the backgroundlight
should be replaced.
good luck
hans
Posted on Aug 26, 2008
  • 19 Answers
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
Posted on Jan 18, 2010
Occasional yellow flashing
check for bulged capacitor in the power supply board.
Aug 12, 2012 | Sceptre X24wg 24 1080p Lcd Monitor
Light comes on like itnhas power , but no display
Blue light keeps flashing as though it is on but no picture or sound and it does not turn off
May 13, 2011 | Sceptre X37sv-Naga 37 in. LCD Television
Bought a second hand Sceptre x24wg-naga, now has has sreen on sustain failure, When powered up the power remains on but picture is only on for a few seconds before going out while still showing power...
It can be component (caps) failure in the power supply, that will be the first palce to look. As you can see in my failed LCD TV and monitors albums (you can se SCEPTRE albums).
Worst case will be bad lamps assembly due to poor sodlering works.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 12, 2011 | Sceptre X24WG-NAGA Monitor
I am trying to connect a Sceptre monitor
Will the monitor work on another computer? Will the computer work with a different monitor? Are you connecting the vga port to vga output on the video card or the dvi input to the dvi output on the card. You may need a video card with hdmi output.
Jul 17, 2010 | Sceptre X24WG-NAGA Monitor
Sceptre x24 has suddenly stopped working. Monitor
if you are using integrated video, your integrated video is fried, done gone. if you have a pci or pcie or vga video card, its gone or blown or dead as a doornail. replace the video card and youll be up and running again
Jun 04, 2010 | Sceptre X24WG-NAGA Monitor
Sceptre X37sv-Naga powers on no picture
Do you get sound? If you do, then the problem will be in the backlight inverter board. You should have 24vdc presents on the main power supply which supplys the power to the inverter board. Please verify that is the case.
Nov 02, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre 40" 1080P LCD HDTV Display Upside Down
I have a 32 inch sceptre naga. when i turn on a tv, the blue screen appears for less than a second and then goes blank. the sound is still on. what could be the problem
mine does the same thing, before... it would come on when i turned it on & off. But now it blue screens then blank black. Blue means if it stays blue & i turn on my computer it will show all the computer stuff, i have not used TV yet.. But if you can get it to stay blue you can change things with the cc control, or swap..
If you find how to keep it blue let me know please..
Apr 17, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Sceptre X20G Naga II 20.1" Widescreen monitor
I am working on one of these for a customer. Found leaky cap on 5 volt power supply. replaced it, still no backlight. Looked at the inverter with an o-scope and it runs for a few seconds then shuts off. I hooked a ccfl across each of the transformer secondaries on the inverter and it lit up! I believe the problem is failed ccfl units. There is plenty of voltage there to light them up, I have an rf burn on my thumb to show for it. I have not looked at the ease of dis-assembly of the display to replace the backlights. It does not look easy.
Oct 22, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Sceptre monitor will not return from idle.
The only workaround was to not use the DVI cable but to use the old VGA cable. You still get the same resolution.
I have a different ATI board, so I'm thinking it's an ATI+Sceptre on DVI input bug. Anyway, use the VGA cable, it'll work.
May 22, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X24WG-NAGA Monitor Logo
74 people viewed this question
Top Sceptre Computers & Internet Experts
Robert Veldman
Robert Veldman
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
