Question about Canon PIXMA All-In-One Photo Printer with 3.5" Color LCD Viewer
Do i need a phone line into the dsl and another for the mx320
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
Yes you do need a phone line for DSL.
Would you be kind enough to explain the problem regarding the 3.5" display on your'e printer !
Posted on Nov 06, 2010
How to fax something using a canon mx320
If you have connected the device to a phone line, to send a fax simply press the FAX button, load the documents you wish to send in the top feeder, dial the number you wish to fax them to & press either start button
Aug 22, 2014 | Canon PIXMA MX320 Color USB InkJet Printer
Can canon mf4370 fax on dsl line
Fax machine operation can be interrupted by DSL lines, however, because the DSL signal is also transmitted through phone wiring. This can result in a loss of data in the fax if steps are not taken to prevent it. Fortunately, this is not a difficult thing to fix.
Items you will need
  • DSL filter
Step 1
Unplug the fax machine from the phone jack.
Step 2
Plug your DSL filter into the phone jack. DSL filters are specifically designed to eliminate interference from the DSL line on your phone line.
Step 3
Plug the fax machine into the phone line jack on the DSL filter. You can now use your fax machine and DSL line at the same time without risk of data loss or interference.
Feb 05, 2013 | Canon ImageCLASS MF4370dn Laser All-in-One...
How to fix wifi disconnect when cordless phone rings
If you are using DSL, you most likely do not have your line split between the internet and phone. At that point, you need to find the filtering devices provided with your DSL modem and connect one phone line from the phone slot to the cordless phone jack, then connect another phone line from the internet slot to your DSL modem.
Jun 07, 2011 | Acer Aspire 5742Z-4200 Notebook
Theres no dsl light on the router, its a d link dsl2640b. so i need to know if its broke, the power light is on and the status light but no dsl light and no internet light on router, the pc is showing...
The flashing DSL light means that the modem isn't seeing the DSL signal on the phone line it's connected to. This might be due to modem failure, but it might also indicate a phone line problem. The most common trouble I run across is an unfiltered device connected on the line that interferes with the DSL signal. Other than the modem, all devices (phones, fax machines, security systems, etc.) need to be connected to the line through a filter. Check to be sure something hasn't been connected without a filter. Sometimes a phone gets moved or a new phone is added that gets plugged in to a handy jack without being filtered.
If you can, try connecting another modem to the line. You may be able to borrow one, or find one at a resale shop. I see them quite often for only a couple of dollars, leftover from people changing to FiOS or cable service. This can help determine if the modem is responsible.
One final possibility: your DSL service has been cut off. I've had two cases where loss of DSL was a phone company issue that they needed to fix at their office. (One following some wiring work done in apartment building, the other when service was mistakenly disconnected from the wrong customer.)
This kind of trouble can be a headache to solve, but it can be solved. Good luck and thanks for using Fixya!
May 21, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I have poor speaker phone qualtity. Do I have to
The speaker phone quality has been one of the sore points of these phones, it has nothing to do with your DSL.
As long as you have a working filter in the line you should have no problem with DSL regardless of the line it's attached to. However, you will have to make sure the wiring is done correctly for the intercom to work.
Jan 09, 2010 | RCA 25425RE1 Phone
I have a hard wired wall mounted telephone (not modular). I need to insert a DSL modular filter into the circuit. What do I need to do convert the hard line to a modular line so I can insert the DSL...
Here's a thought. The DSL filter doesn't have to go on every phone, just the phone line that FEEDS the phone. In old residential, the phone line is looped to each location. If you open up another jack and break the loop, you could possibly find out where the first jack is in your house, put a duplex jack there, feed the DSL modem, and filter all the rest of the lines in the house at that location. Or, go outside, bring the dial tone in on the black/yellow or orange pair, install your DSL modem on that pair, and filter the dial tone back into the green/red pair for the rest of the house.
You can also buy a wall plate with DSL filter in it. Screw your chair closer to the floor before you go here :-) http://www.sjtelecommunications.com/sut-630lccl-s.html
Carl
Nov 13, 2009 | Bell Lands Phones
GE 29488
Note: Intercom features are NOT compatible when DSL is installed on line 1.You may need to reconfigure it for dsl internet if it is installed on line 1
May 27, 2008 | GE 29488GE2 Corded Phone
12 people viewed this question
old marine
old marine
