Question about Alpine CDA-9805 CD Player
Set clock on a alpine cda-9805. I can change hr not min
  • 8,197 Answers
Heree is how to set the time on the radio.
1 In the Clock priority mode, press and hold the DISP/
TITLE button for at least 3 seconds while the time is
displayed. The time indication will blink.
2 Turn the Rotary encoder to adjust the hours while the
time indication is blinking.
3 When the hour has been adjusted, press the Rotary
encoder.
4 Turn the Rotary encoder to adjust the minutes while
the time indication is blinking. The time is automatically
set 5 seconds after the minute adjustment. The time
can also be manually set by pressing the Rotary
encoder
If you need the manual is on the link below page 6 tells you how.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDA9805.PDF
Good Luck
Posted on Nov 06, 2010
What's your problemI bought a used car that has an alpine cda 9805 radio. It has an auxillary cable that appears can hook up to my I pod nano. I can't find the function/ mode on the radio to g
The source/power button in the top left corner changes the mode. Press the button until the aux appears. The auxillary device must be plugged in to register on the stereo.
Aug 19, 2012 | Alpine CDA-9805 CD Player
How do you change the time on the clock? Don't
This is from Page 7 of the manual available on Alpine's site:
moz-screenshot-1.pnghttp://vault.alpine-usa.com/products/documents/OM_CDA-9884.PDF
Setting the Time
1. Press and hold F/SETUP for at least 2 seconds to activate the SETUP selection mode.
2. Turn the Rotary Encoder to select CLOCK ADJUST,
and then press "magnifying glass"/ENT
3. Turn the Rotary Encoder to set hour.
4. Press "magnifying glass"/ENT
5. Repeat steps 3 and 4 above to set minute.
6. Press and hold F/SETUP for at least 2 seconds to return to normal mode.
I hope that helps.
May 21, 2010 | Alpine CDA-9885 CD Player
Intermittent power to head unit
no inline fuse? I usually just slip the wire inside the battery connector, remove connector lay wire across battery with stripped end running up the side of the battery terminal place connector down on terminal and wire, tighten connector back up.
Feb 21, 2010 | Alpine CDA-9805 CD Player
My display stays on for about 3 seconds then it turns off until
If this model has a detachable faceplate,
Remove the faceplate and clean down the contacts with metho and a cotton bud.
Over time usually corrosion and dirt etc builds up on these terminals making them loose cotact when you touch the faceplate.
This is the most commonly known problem alpine units.
Other common problems is the power supply failing /amplifier.
Hope this helps you out
Cheers
Steve
Apr 02, 2009 | Alpine CDA-9805 CD Player
Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Jul 23, 2008 | Alpine CDA-9805 CD Player
How do I get the clock to always display on my head unit Alpine 9884 cda
Look for "TITLE" button on the right hand side of the display.
press TITLE repeatedly until the time is displayed.
set time.
when power is OFF but iginition is ON press TITLE to display the time.
i hope this solution helps .
Jul 11, 2008 | Alpine CDA-9856 CD Player
Setting time on clock
Press "Title" until time is displayed. Then press and hold "Title" for a few seconds until time is displayed. Turn the silver knob to change the hour, after hour is set, press the silver knob to activate minutes. Turn sliver knob to change minutes. Press silver knob to end.
Feb 15, 2008 | Alpine CDA-9811 CD Player
Alpine CDA-9805 head unit - frequency hops
make sure no switches are jammed on radio or radio face.Liquid spillage and or intermittent switches on tunning section can also cause this.
Nov 29, 2007 | Alpine CDA-9805 CD Player
Alpine CDA-9805 CD Player Logo
276 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
