Question about Schlage BE365-CAM BE365CAM619 Satin Nickel Electronic Security Camelot Elec
I press the schlage button i can unlock the door by turning the button
  • 963 Answers
The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Complete installation & programming instructions can be found here:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security... 365
Good luck--and please provide feedback if this helps!
Posted on Nov 08, 2011
Keyless schlage lock opens when schlage button is pushed
  1. Remove the two screws on the back plate.
  2. Disconnect the battery
  3. Remove the two screws on the inside of the lock so that you can remove the entire lock.
  4. Once you have removed the lock from the door take the backplate in hand
  5. Right above the orange plastic piece there is a small black egg shaped cam.
  6. Turn the black egg shaped cam to the side and then turn it back down so that the arrow is pointing down.
  7. If you do this right the deadbolt will stay in the unlocked position. The deadbolt will not retract when you turn the cam because it should be completely disconnected
  8. Once you do this correctly you will reinstall the lock in the unlocked position.
This also will fix the light not coming on when you press the Schlage button.
Dec 15, 2017 | Schlage Locks & Locksmithing
Our schlage lock with thumbturn on inside and keyed on outside. When unlock inside, knob turns freely as if it is really unlocked but if I close door, I get locked out. Please help
Be sure the outside knob is unlocked before closing the door.
Schlage locks do not lock the inside knob or lever. After releasing the turn button, also turn the inside lever or knob, then check the outside knob.
What model of lock is this?
Apr 09, 2014 | Locks & Locksmithing
How to change baterry o schlage be365
To change the battery on the BE365, you need to remove the inside cover by removing the two screws (one above and one below the deadbolt knob). Be careful to tuck the wires inside the lock so that they will not be crimped when you put the cover back on.
Do you here a beep and see a flashing light? Usually if pressing the Schlage button unlocks the deadbolt, your installation was done improperly. The cam on the base plate must be vertical and the bolt must be correctly installed.
You will always be able to lock and unlock the deadbolt with the inside thumb knob.
I hope this helps.
Dec 04, 2013 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
Door will unlock without entering code
"Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial? "
Feb 15, 2012 | Schlage BE365-PLY BE365PLY626 Satin...
Can't push one button to lock anymore
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the "dial". When disabled, you have to enter the user code, then turn the dial. So either way, you still have to turn the dial.
To enable/disable this feature, enter your Programming Code --press Schlage button--press 7
"How can I program my electronic keypad lock when the instructions with the Programming Code have been lost?"
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
Good luck-and please provide feedback if this helps!
Aug 12, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Schlage camelot key pad does not engage exterior locking knob when you press the schlage button. I have tried three different locks.
Here is a link to the installation instructions:
It sounds like you may have the Turn Lock Feature disabled. View and scroll down in the instruction sheet to the Troubleshooting portion, where it says " Pressing (the) Schlage (button) does not rotate deadbolt" The solution is to push the PC button, then the Schlage button, then 7 to enable the turn lock feature.
Here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
May 02, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
I have a BE365 Lock on my door. When I go to lock the door it wants the code punched in and the knob turned. When i unlock it, it just wants the schlage button pushed and knob turned. HELP
How do I enable the alternative setting (Code Turn)? (BE365 Deadbolt only)
1.) Enter your current 6-digit programming code
2.) Push the button
3.) Press 7 on your keypad
Nov 16, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
I push scglage button and unlocks the lock
http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx#5
Why can my electronic keypad deadbolt (BE365) be unlocked without a four digit user code when I press the "Schlage" button?This is most likely due to an installation error. When the lock is assembled on the door, two steps of the installation must be followed to insure proper operation. The deadbolt must be installed in the door edge with the bolt retracted, and the gray plastic cam on the interior mounting plate, through which the flat metal driver bar passes, must be pointed down (see below). The gray plastic cam has a triangle embossed on the end opposite the driver bar which should align with a matching triangle on the orange plastic cover plate below. These instructions are also embossed on the orange plastic plate.
Troubleshooting Image 2
If the cam is improperly aligned, the lock must be disassembled to a point where, with the bolt retracted, the cam can be turned to the correct position without moving the bolt. This will require withdrawing the flat driver bar completely from the cam before turning the cam. The driver bar will then pass through the cam at a forty-five degree angle when the lock is reassembled.
Sep 07, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
Schlage BE365-CAM  BE365CAM619 Satin Nickel Electronic Security Camelot Elec Logo
193 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
