Question about Toshiba Regza 32LV67U 32 in. LCD HDTV
Color screen On my LCD Tv, suddenly all the colors went to green and purple--no reds.
  • 4 more comments
  • Taken11 Jun 15, 2008
    Nothing but green & reds on screen. Tried adjusting everything under the menu for video settings, but nothing works.
  • Anonymous Oct 21, 2008
    I have a SONY BRAVIA KDL-46S2010 I bought approx 2+ years ago. Occasionally, after I change the channel, the picture turns green&purple and can only get normal color again by turning TV off and on again. Have had no other problems...What's going on?? Bought it from Best Buy and it's now out of warranty.
  • barneypo Oct 23, 2008
    My Bravia KDL-40S2000 is exhibiting the same think. HD channels are just fine. Other digital and analog channels display human flesh tones in purple and eyes of green.
    It seems like the TV has to be on for quite a while (be warm or hot) before this problem occurs. Turning the TV on off and on doesn't seem to help.
  • vernonbc Nov 14, 2008
    I have a Sony BRAVIA KDL-46V25L1 (same as KDL-46V2500, I think, the only difference is it was sold at Costco). When the TV has been on for a few minutes (not all that long), and I am watching High Definition channels, then, if I switch down to the low definition channels, the colors change to only green and purple. The only way to correct this is to shut off the TV and then turn it back on. If I happen to go back to HD again and then back down to low def, same thing. Other than this issue, the TV is great, crystal clear colors and HD channels are perfect, we have been very happy with it. This strange purple / green only issue started about a month or so ago. Luckily, I have a month left before my one-year warranty is up. I am returning it to Costco for a refund... I don't want to be left having the TV if turning off and on stops correcting the color issue. And its kind of embarassing when company is over and they are flipping around the channels.....
  • andrew34jon Dec 13, 2008
    i have the same problem with my new bravia kdl46w4100....green and purple screen on low def channels after watching hi def.....turning off for a minute seems to cure it....i am pi##ed off about this....just payed 1500 at my local sears....
    called SONY..they said it was my charter HD cable box...having a new box installed tomorrow..hope this fixes it??? any body have a solution??
  • ryad0801 May 11, 2009
    I have a 37" 1080p toshiba lcd and a charter hd cable box. I use the the dvi output on the cable box and im using a dvi-to-hdmi cable to connect to my tv. Ive had the tv almost a year and i recent started having the purple and green color problem with standard definition channels. HD channels, dvds, video games, etc. work fine. If i unplug the hdmi cable from the tv and plug it back in the problem goes away. Reseting the cable box and/or turning the tv off and on again do not fix the problem. Im having charter replace my cable box in a few days ill post again with my findings
Subsequent to my Nov 14 2008 posting... shortly thereafter, I had returned my Sony BRAVIA KDL-46V25L1 (KDL-46V2500) to Costco. Then, (after trying a 52" Samsung, whose picture was nowhere near as good as Sony in High Def , but that is another story) I purchased a newer (one year newer) Sony BRAVIA KDL-46W4100 with 120 Mhz refresh rate.
What did I find?
The same purple/green image problem (“The Problem”) exists in the newer model Sony as well ! !
I believe the actual issue is with the TV, not the cable box, in that the TV contains faulty logic in in the way it handles switching from one input format to another. Turning the TV off and back on ‘resets’ the TV, and corrects the TV display (at least in the case of my Sony BRAVIA KDL-46V25L1 (KDL-46V2500) and Sony BRAVIA KDL-46W4100).
That action should have little impact on the cable box output.
My Shaw High Definition cable box has two output options for HD: Component RGB, or a DVI output. It came with an RGB cable, and a DVI / HDMI cable (DVI end for cable box, HDMI for TV).
When I use the Component RGB, my TV does not have “The Problem”; everything is fine with all the various cable box output settings I have tried.
When I use the DVI / HDMI cable, I get the “The Problem”.
“The Problem” only appears under one specific set of conditions as noted below....
My cable box can be configured to handle output for standard definition (SD) channels in one of four different formats: Nothing, 480i , 480p, or STRETCH. (where ‘Nothing’ lets the signal pass through as-is ).
ONLY when the cable box is configured to send SD channels as 480i does “The Problem” arise.
The TV has an issue (bug in video logic?) handling the switch from 1080i to 480i, only when using the DVI / HDMI cable between cable box and TV.
IE “The Problem” only seems to occur while using both the DVI/HDMI cable, AND when the cable box channel is changed from a high definition 1080i channel to a standard definition channel AND the cable box is set to convert the output of the SD channel to 480i .
By changing the cable box to send SD channels as ‘Nothing’, or 480P, or STRETCH , and “The Problem” goes away.
Or, using the Component RGB cables, and “The Problem” goes away !
Hope this helps.
Posted on Feb 03, 2009
If you are hooked up with a DVI cable you need to either use hdmi, component cables or turn off the non hd override...
Posted on Feb 02, 2009
  • 3 Answers
I've seen this same switching HD-normal tv color issue problem before, and not just in sony LCD, also in toshiba and mitsubishi as well, same case scenario, DVI (cablebox) to HDMI input (TV), wayching HD channels, you go to a normal channel, and then in between the switching you have the color issue.
I think that the software/ firmware in the cablebox, is the cause of the problem, and some microprocessors in the tvs are sensible about this. Samsung is the only tv that is not as sensible as the brands mentioned above, this does not means is a better brand.
The problem happens just using the DVI output and nothing else. Solution: TV is not the problem, replace cablebox with a HDMI output.
Posted on Apr 29, 2009
I had the same problem with my SONY LCD TV. I have 5 cables (green, blue, red, white and one other) connected to the back of the TV. I removed all 5 and then reconnected them. The problem was resolved.
Posted on Nov 26, 2008
How do I repair the color on my Samsung LCD TV. I can still see the picture but 3/4 of the TV goes green/purple/pink and the bottom 1/4 has normal color.
The T con Board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 28, 2016 | Samsung Televison & Video
SAMSUNG LCD 550 SERIES TV COLOR GREEN AND PURPLE
Sounds like t'Con board fault. Contact any service technician to make it confirm.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, screen faults & possible causes to LCD screen are given with illustrations.
Jul 29, 2014 | Samsung Televison & Video
We've had the Sony DAV DX150 for a few years and now all of a sudden when we play a DVD the color is all messed up. It displays in mostly greens and purples. If we adjust our TV settings, by putting the...
Hello ,im curious as to whether your using component cables from the dvd to the tv (red,green,blue) if so than i suggest you check those because it sounds like your missing a color,check the red cable specifically.
Jan 18, 2011 | Sony DAV-DX150 System
My toshiba 32 inch lcd tv has green ,red,and purple squigly lines on the screen Model # is 32AV500U
Change Your Regulator on your Color Mixer check the choke beside it the little yellow trasfomator beside.... It maybe damage too....
Sep 21, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
My lcd tv has a purple screen and no sound
same problem all set to replace TV but tried another source DVD instead of dish and it was fine. Possible the cable (cheap HDMI) but reboot the dish (hard) pull the plug and fixed it up, probably the HDMI connection at the source or the TV (or the cable)
Mar 28, 2010 | Samsung Computers & Internet
The color seems to be off. No red, and lots of purple. This is a Toshiba 57H81 wide screen big box tv. It was purchased in 2002.
Could be a bad board within the tv but it is sometimes the source input meaning it could be dvd player, cable/satellite box, etc causing the loss of color but it is unlikely. I have one of these tvs and they use red green and blue projectors to reproduce the colors so when the red projector fails then you get purple which is green and blue colors combined without the red. I have found it to be sometimes a bad connection inside the tv and I found insects such as roaches inside others. Using extreme caution when opening the rear cover of any tv due to dangerous and fatal high voltage. You might find that simply cleaning out the inside of tv and reseating all the connectors might resolve your issue otherwise you would have haul this tv to a repair shop where you pay half the price of a new flat screen lcd for just repairing this tv which will probaly have another color go out next month.
Aug 15, 2009 | Toshiba 57H81 57" Rear Projection...
Red Color not working
Does this only show up in one connection IE: HD cable box, DVD player etc, If connected to a HD cable box a loss of red can mean a defective red component cable.
Aug 15, 2009 | Televison & Video
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
May 21, 2009 | LG 37LP1D 37 in. LCD Television
Color problem with TV
Are you getting Green or purple or pink patches all over the screen?
This could be a problem of Degaussing. Have you placed any Magnetic source near the TV recently? Some Tape recorder or walkie talkie or a Speaker, etc? The Magnetic field created by any of the above sources can cause coloured patches over a colour TV screen.
It also happens if you shift the TV from one location to another.
The third possibility is that the Picture Tube's Red Output stage gone faulty. Unless you are a trained Solid state Electronics Technician, there is nothing you can do. Better go for a trade in.
Feb 22, 2008 | Panasonic CT-27G21 27" TV
Toshiba Regza 32LV67U 32 in. LCD HDTV Logo
1,297 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
