Question about Dryers
Our gas dryer is so hot you can't touch the drum. Heat setting does not appear to work.
    President:
  • 3,074 Answers
Sounds like a venting problem, I would inspect and ensure that the dryer as well as the vent tube is cleaned and free of obstructions.
Posted on Nov 06, 2010
I have samsung dv220aew/xaa dryer, that gets too hot and kicks code HE. New element, thermistor and cleaned thoroughly. Gets hot, codes on all heat settings. Any ideas?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Apr 21, 2015 | Samsung Dryers
Have a gas dryer ..with. A burner high limit fault . Sign... Runs for 2 seconds and turns off
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Apr 19, 2015 | Dryers
The dryer is getting very hot and then the timer appears to be sticking at 20 mins to go. I have changed the thermostats already.
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Mar 16, 2015 | Hotpoint Dryers
Why is my tumble dryer hot on a low setting
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Feb 14, 2015 | Dryers
Frigidaire Affinity Gas dryer, had a technician replace the thermal limiter after getting an E66 error code, twice, about 6months ago, he advised me not to use the hottest setting and thing have been
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Oct 06, 2014 | Dryers
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
see this causes and fix it. God bless you
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Sep 28, 2012 | Fisher and Paykel Dryers
Regardless of settings, my Amana Commercial Dryer does not stay hot all the time whilst drying. Sometimes when I open the door, the air clothes are cool to the touch. Then some time later they are hot...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Amana Dryers
Hello-I have the Kenmore Electric Dryer model 110-66842501 series 80. Started the dryer and noticed a burning smell & the dryer was unusually warm to the touch. Now there is no heat. Drum turns...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 12, 2010 | Dryers
I just bought a gas dryer - takes forever to dry clothes
check the high limit switch/thermostat on the burner housing and if they are weak they will cycle the heat off too soon and it wont build the heat you have it set for,just bypass it with a jumper wire to test it,if this is the problem,dont leave it bypassed,replace it as it is a safety feature to prevent a fire
May 09, 2010 | Kenmore 95087 Gas Dryer
GE Gas Dryer (Model DQSR 483) Drum works but does not heat
There are three things besides what you aleady checked:
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 01, 2009 | GE DBXR463EBWW Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
