Monitor says Hi When power on - CPU fan works, graphic card fan works,PSU fan works,. DVD RW opens. Mouse & keyboard transmiter not working,DVD ROM not openning and i cannot hear hard drive working. Monitor is ok, cable ok, I replaced 350W PSU whith 300W in working order then reconnected every possible connetions in the box incl.reseated RAMS, CPU and replaced AGP graphic card with new one, but no luck. OS Windows XP SP2, Processor-3gH Intel Pentium 4, 8Kb primary memory cache,512Kb secondary cache. Thank You for your time
  • Chris Replogle
    Chris Replogle May 11, 2010
    Does your computer make any beeps when you turn it on? If so, how many and are they for example 1 long beep and 2 short beeps? If not, did it ever? Should have made 1 quick beep when it worked when you turned it on unless this function has been disabled or the internal speaker isn't connected.
    Also what brand and model is the motherboard. If you don't know, what make and model is the computer.
    Problem Solver:
  • 13 Answers
OK then I would basically do what was posted above except I have seen some motherboards that say to not power up the computer when you try to reset the bios. If it has a jumper to reset it, set the jumper to reset and leave it like that for a few min, then switch it back to the previous settings. If you don't have a reset jumper for the bios, remove the battery (its the little coin looking battery) for about 30 mins then hook it back up. Disconnect all the cables to the drives and any external devices you might have like mouse, keyboard, usb devices etc.
Take out any interface cards you might have like network or modem audio card etc. The only thing you want is the cpu, ram and video and power it up and see if you get the anything. You should at least see the system info text aka the bios screen. Then hook up the mouse and keyboard and try booting up again. If its working at this point, then install the interface cards one at a time. If it still works move on to hooking the drives back up one at a time. This is basicly the same as what was posted above but I wanted to add the warning about not powering up when the bios is in reset mode. I use to do the same until I recently read in a Asus manual to NOT power up the system while the bios jumpers are set to the reset position. He also didn't mention removing all the interface cards and unplugging and other external devices like the usb stuff and the mouse and keyboard. Not saying there is anything wrong with his response I just wanted to justify that my answer isn't the same.
Posted on Jun 15, 2008
  • Chris Replogle
    Chris Replogle Jun 15, 2008
    Just thought of one other thing, if you can, try swapping out the memory or if you have more than one piece try the first step I mentioned with just 1 stick of memory. If it works then add the additional stick of memory. If you have more than 2 sticks, add them 1 at a time. If the first step doesnt work with 1 stick of memory and you have more, try a different stick or a different memory slot.
  • 106 Answers
Try and kill the bios. Find the jumper next to the battery on the motherboard and move it from position 1-2 to 2-3 ... press the power button a few times. then put the jumper back to normal and give it a shot.
I would disconnect the cables first before anything and attempt to boot the system.. if it boots, then start plugging hte cables one after another until you find out what's causing the machine not starting correctly.
Good luck.
My hdd led is lit up, and the keyboard leds are blinking... but there is no display on the monitor... other leds on the cpu are not lit up... whats supposed to be the prblem
one of your componants is more than likely faulty ,id start with trying another psu(power supply) that u know is working then try removing the ram 1 stick at a time and the hard drive and dvd rw/rom graphics card and plug into onboard graphics make sure u remove one componant at a time between trying to power up the system until u narrow it down it will be diffacult to correctlly diagose the problem
Mar 11, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
When startup button is pressed fan runs and orange LED comes on for a second and then stops (have changed motherboard and tested with different PSU still not working).
Try only motherboard, ram and CPU, without keyboard, mouse, grafik card, hard disk, cd or dvd rom. If you have one normal beep, you have trouble with some of another parts.
If you still have a problem try motherboard, another ram and CPU.
If you still have a problem, than you have trouble with CPU.
Oct 30, 2009 | Dell Dimension E521 PC Desktop
BIOS WON'T START OR LOAD, ANYONE CAN HELP ME? Mainboard: P5S-MX SE Having troubled my CPU, it works for 2 years but now this is what happened. It won't start. First, i detached all the hardware attached...
Remove The CMOS Battery, For 10-15 seconds to reset The Bios to it,s default settings.
Try the memory Module/Ram in a different Slot.
Re-seat the CPU.
Mike @ Compurepair.
Oct 16, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
My computer turns on but nothing responds
Most likely your motherboard was DOA. Send it back for a replacement. Sounds like you've done all the troubleshooting double check the power supply connector...especially the P4 connector that I have occasionally forgotten to plug in...that will also cause the symptoms you describe.
Aug 14, 2009 | Intel D915GUX Motherboard
Replaced my power supply, now keyboard and monitor wont work.
Believe it or not, if you have a floppy drive in your computer, try unplugging it and disconnecting the data ribbon. Many times, damaged floppy drives can short out motherboard functions and even prevent computers from powering up. If that doesn't fix it, then get a usb keyboard and mouse set (wireless would be fine) or borrow some, and see if they work. If they do, then the power outage damaged the PS2 ports.
May 25, 2009 | E-Machines eMachines Monitor E15T4
Ccomponants will not power up
Your hard drive is junk. Replace the hard drive.
May 23, 2009 | Computers & Internet
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Nvidia GEforce 8600gt 1gb compatible problem?
i must connect two graphic card on a pc, how to do it?
Apr 22, 2008 | Computers & Internet
New graphics card
Intel Pentium® III, AMD™ Duron or Athlon™ class processor or higher
128MB system RAM
A 300W system power supply
An AGP 2.0 (or higher) compliant motherboard
50MB of available hard disk space
CD-ROM or DVD-ROM drive
Microsoft® Windows® 98, ME, 2000, XP, or Windows®
VGA or DVI-I compatible monitor
This is what you need for graphic card to work!!!
Its very good card!!!
Jan 22, 2008 | Computers & Internet
Computer Not Booting Up
normaly ther are two reasons for pc not showing the disply
1 memory card mismach
2 graphics card mismach
get the specification of the mother board and correct the above errors the pc will work if u need more assistace please write to me
Oct 23, 2007 | ASUS AI Lifestyle P5N32-E SLI...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
