Question about Sharp AR-5316 Advanced Digital Imager Copier
AR-5316 SHARP COPIER
I have two years old ar-5316 copier now my copy comes with white strips on imagev.
  • Sharp Master
  • 2,794 Answers
Could be the scanner or the USB cable. Do you have replacement USB cable?
Posted on Jun 17, 2008
How to clear F5 error in Sharp AR-5316E, my technician have already cleaned the glass and all the optics in the scanner including the lamp and the white strips on bottom but still the error remains.
F5 errorContent Copy lamp error
Detail Copy lamp voltage detection error
Cause Power unit trouble, Copy lamp trouble
Inverter trouble, MCU PWB trouble
Check and remedy
Replace the power unit.Check the copy lamp ON with SIM
5-3.
Replace the copy lamp.
Replace the inverter.
Replace the MCU PWB.
Aug 31, 2012 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 device driver for windows 7
5316 copier doesnt work with win7.you should use win xp
Aug 01, 2010 | Sharp AR-5320 Black and White Copier
Sharp Photo Copier AR 5316
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} E7-11 Shading troble(whife correction)
IMPRPER CONNECTION OF THE CCD UNIT CABLE DIRT ON THE MIRROR,THE LENS,AND THE REFERANCE WHIT PLATE
copy lamp lighting abnormality
ccd unit abnormality
MCU PWB abnormality
(when occurred in the scan position)improper installation of the mirror unit
Jul 31, 2010 | Sharp AR-5316 Advanced Digital Imager...
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
Dear All We want to but sharp Machine but we ...
5316 ,16 copy per minute
5320 , 20 copy per minute
May 20, 2010 | Sharp AR-5320 Black and White Copier
-COPIERS - AR-5316 Advanced Digital Imager Copier: i m not getting the printer driver of sharp AR-531...
The printer driver comes on installation CD when buying a new copier. If you are using it as a printer, insert the CD inside the CD-ROM drive and click open the file written set-up and follow on-screen menu. Connect the USB cable when prompted to finish your installation. Now you can print using your Sharp AR-5316 and that is the driver for it.
May 18, 2010 | Sharp AR-5316 Advanced Digital Imager...
Installer of sharp AR-5316
Remove the screws marked and all tapes around the copier, open the tray and remove the screw supporting it. Open the front cover and unscrew the green screw holding developer unit and pullout the unit. Open the 3 screws and pour the developer evenly and return it back. Remove the seals on the toner cartridge and insert it. Power on the copier and make a copy.
Nov 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
How can install the sharp ar-5316 black and white cartridge
Hello sir; you have to open the side door first and then open front door , then slide out TD cartridge and drum cartridge, it will automatic reset.
Jul 11, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
75 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
