Question about ECHO, Inc. PB-251C Handheld Blower
I have a 2 stroke engineer leaf blower that will not start. I have spark and using starter fluid gets it going but it quits. I know I have gas getting into the carb. - I think problem is probably in carb. I have taken the carb off and tried to clean it but still not working. Is it worth it to have it fixed or better to buy new carb. Appreciate any advice/insight. Thanks Paul
  • 4,349 Answers
Paul, fix the old carb. They can gum up and sometimes need to soak (disassembled and soft parts removed, like the float, gaskets and inlet valve.)in carb cleaner and then be blown out with compressed air.
Posted on Nov 06, 2010
Homelite 26cc leaf blower got gas,spark,will not start with starting fluid
1 check your comprassion ratio on the cylinder , 2nd fuel hose broken or blocking the fuel 3th or fly whell key broken, start with new spark plug on 2 stroke engine 4th check for exhaust blokage 5th check the switch off and on for shortage, Fit fresh fuel,Check choke for floating the engine.
Jan 30, 2017 | Homelite Garden
CAN'T GET I
Remove the spark plug and spray about 2-3 seconds of starter fluid into the cylinder. Put the spark plug back in and try to start it. If it starts and/or runs for a minute but does not restart unless you add more starter fluid to the engine, the carb probably needs cleaning, rebuilding, or flushing of the old/bad gas. If the gas is older than 6 months replace it and start with a fresh tank.
Feb 05, 2016 | Garden
How to start ryobi leaf blower model 09050 i tried everything i primed it with gas tried shooting starter fluid in it
Do you have a spark on the plug? Did you use gas-ethanol mix?
Use premium only.
Sep 12, 2015 | Ryobi Garden
Do i mix the gas or use straight gas
The answer is that ALL 2-stroke engines requires that you mix oil with the gas. ALL 4-stroke engines do not take oil in the gas. So the simple answer is if there is no place to add oil, then you have to mix oil in the gas - not the same kind of oil though! I don't know this particular model, but I have never seen a 4-stroke wearable leaf-blower. The kind on wheels could be either, but most (maybe all) are 4-stroke.
Sep 18, 2012 | Homelite Leaf Vac Attack
Snowthrower. Won't even fire. Can I just clean carburetor?
See my tip on diagnosing small engines. It works for 2-stroke or 4-stroke engines.
It is best not to use starter fluid. Aerosol carb cleaner is what I use.
Jan 02, 2010 | Toro Lawn Mower With Toro Power Tools
I have a poulan pro 25cc leaf blower that will not start.....i can barley get it to turn over just a little. it has fresh gas and has only set a couple of weeks.
1) Make sure gas mixture is 40:1 2) Put in new spark plug
If that dosent work try starter fluid to get it going.
Aug 12, 2009 | Poulan Garden
Wont start
try some starting fluid in the intake, clean the spark plug. is it an old blower?
Mar 20, 2009 | Craftsman 4 Cycle Blower/Vac
I have a craftman yard vac with a tecmseh 4.5. She has failed to
Hi gr2954;
Lots of the starting problems with 2 cycle engines (weed eaters, blowers, chain saws, etc) are caused by leaving them stored for long periods of time with the oil/gas mixture left in them. what happens is that a residue forms on parts in the carb.
Try the following: empty the fresh gas out of the blower. add a gas stabilizer to the existing gas you plan to put in the blower. You can get this stabilizer at any auto parts store. While you are there get a can of spray start fluid. Put the fresh, modified gas in the blower. Take the spark out and spray some starter fluid in the plug hole.Replace the spark plug and try to start the engine.It will probably take a few cycles of doing this to get the blower to stay running.
when you put the blower up for a long period, empty the remaining gas out then start the engine and run it till it stops. this gets the remaining gas out of the carb.
Nov 30, 2008 | Garden
ECHO, Inc. PB-251C Handheld Blower Logo
517 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
