Question about Cozy (W352E) Heater
Cozy floor furnace the pilot light, lights ok but when i turn the knob on the gas valve to on the gas does not light jerry----------------castloh92@gmail.com
    President:
  • 3,074 Answers
Http://arnoldservice.com/Troubleshooting_Heating_Problems.htm
Posted on Nov 06, 2010
How to troubleshoot gas valve on a millivolt gas floor furnace
I've worked on MANY floor furnaces, and the previous answer is COMPLETELY opposite of what I've experienced. If you've cleaned or replaced the thermo pile, have a decent flame, and allowed about 3-5 mins for the pile to generate a millivolt signal, it should have enough to power the line to the Tatar, then to the valve. You can jump by the wires to the Tatar to check that circuit either at the valve of the Tstat, as long as you're experienced and safe. Now if you hold down the pilot knob and it don't release, you have a damaged valve that should be replaced.
Oct 19, 2017 | Heating & Cooling
Help! I have a cozy wall heater model W355F-D. I have never ever lit a pilot light in my life and honestly, Im a little nervous. Can you maybe help me and walk me through it?
You should have control knob on the gas valve that has off, pilot and on , turn knob to pilot and hold in you should have igniter button press this in and it will spark at the pilot you may have to press this a few time to get pilot to light . when pilot is alight still hold knob in for 30 seconds then turn to the on position .
Nov 19, 2016 | Cozy Heating & Cooling
I've got good flame replaced Powerpile pilot won&#t stay lit
The flame sensor is not producing enough volts to hold the gas valve open for the pilot light. Make sure the SIDE of the pilot flame is touching the sensor. If it in engulfed by the flame it won't work right.
Jan 01, 2016 | Cozy Heating & Cooling
I AM WORKING ON A COZY W501E WALL FURNACE AND CANT GET THE PILOT TO STAY LIT. i HAVE CHANGED THE GAS VALVE, THERMOCOUPLE,AND THE SENSOR FOR THE HIGH LIMIT. THE PILOT WONT STAY LIT.
Pretty much the only thing that will do that is the thermocouple not generating enough voltage for the valve to say it's OK.
Usually you need to hold the button for pilot lighting for 60 seconds. You can use a meter to check that it's generating enough power. The thermocouple has to be in the pilot flame properly.
Check this video:
https://www.youtube.com/watch?v=suen7QlJl4o
Gas furnace will not light Thermocouple test with the multimeter
Or see this site:
How to Test Thermocouple with Multi Meter Heating and Cooling
Feb 11, 2015 | Cozy Heating & Cooling
Shastalaker7
Check the gas valve some can be really finicky, if the setting for pilot is not right bang on in the proper position the button will not go down, and no gas will flow to the pilot. If the button does go down, do you hear/smell the gas flow? If not the valve is toast.Make sure the gas valve to the unit is turned on AND that the service to the house is actually on! I have had many calls for the same issue only to find the gas company locked out the meter!
Aug 17, 2014 | Cozy Furnace, Floor - 90N50A
Old anthes gas furnace with pilot light. burners will not light.blows cold air
Have to think that the thermocouple has failed if the pilot is on but the furnace main burner doesn't ignite
Apr 05, 2014 | Cozy (W352E) Heater
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
Cozy Wall Heaters
On the gas valve, look for a marking that indicates "Pilot". If there is no such marking, you do not have a pilot and the system is electronic ignition. Ok so if you find the pilot position, you will be able to turn a know to that position and depress the knob into the gas valve. At the same time you are depressing the knob, look for a red button that snaps when you depress it. This is a Pizo starter. If you do not have this button, look for a viewing port where you can insert a long match. Once you have the knob depressed and the viewing port open if needed) you should be able to light the pilot with the snapper or match. Before you release the knob on the gas valve, sing "Yankee Doodle". This will give the flame enough time to heat up a probe to the proper temperature and the flame should stay on. Button up any port you opened and then turn the gas valve knob to the "On" position.
Nov 21, 2008 | Heating & Cooling
Pilot ligting instructions
many of the newer furnaces don't have a standing pilot. look to see if you have a gas valve with a knob on top that says off pilot and on. look to see if a tube the size of a pencil comes out of the valve and goes down by one of the burners, look to see if there is a little gold piece of metal tubing protruding down to the opening of the larger tube . that is where you place the match. i prefer to use a grill lighter. safer and positive flame. turn knob to off wait 5 minutes for any gas to disipate. be sure your incoming gas valves are all open . usually at the meter and one at the furnace. usually the handle is in line with the pipe when open. from the off position, turn the knob on the furnace gas valve to pilot position and push down on it as you turn. this lets gas flow to the pilot tube by the burner where you have you flame starter lit and waiting. once pilot lights hold down on button for 3 minutes or less. longer is better to be sure the thermocouple senses flame . then gently release the downward pressure and the pilot should stay lit and you gently turn knob to on. if pilot goes out you may have a bad thermocouple. be especially careful if its lp or propane as that gas does not disipate like natural gas and can virtually lay on the floor till ignited. also consider having the heat exchanger checked by a pro with a carbon monoxide detector. they do crack after a few years and can be deadly when they do. good luck
Nov 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Cozy wall heater
On top of the gas valve you will see a knob. Turn the knob to the position that says pilot. It's on the side of valve. Press the knob down with one hand and take your long lighter stick it by the pilot tube looks like a small aluminum tube should light pretty quickly hold for 30 seconds release the button you have been holding down. Now turn the knob to the on position. Make sure the thermostat is turned off so the flame don't fire up as soon as you turn knob. If you are uncomfortable gas your gas company and they should come out for free.
Sep 21, 2008 | Cozy (W352E) Heater
Cozy (W352E) Heater Logo
449 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
