Question about Kenmore 62722 Electric Dryer
A wheel feel of that connects to my dryer belt for an old kenmore heavy duty soft heat dryer. dont know were the wheel goes so ot will hold the belt snug to the drum
    President:
  • 1,218 Answers
Good day,
If your talking about the idler wheel that tensions the belt, a picture is worth a thousand words. So look here.
http://www.youtube.com/watch?v=9dd1Ac4_pXY&feature=PlayList&p=2489A2388180145E&playnext=1&playnext_from=PL&index=14
Posted on Nov 06, 2010
Kenmore Heavy Duty dryer model # 86873100
The drum belt is lopped through a idler wheel that has a power cut off switch that cuts the power when the belt breaks.
So I don't know why the dryer would heat up if the belt is broken?
Is the top of the dryer very hot. Check the dryer vent tube is not clogged.
Feb 22, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
On my Kenmore Soft Heat Heavy duty gas dryer I am having problems with the the fire lighting and going off intermentently . The fact that it ignites and then goes out makes me think that it isn't...
Hello Jerry,
It is working like its supposed to when the flame goes off, the way all dryers work is the flame(heat element on electric heated dryers) comes on and when the drum exhaust temp reachs a maximum of 155degrees and the flame goes off, the air temp will cool off to 120degrees and the flame comes back on and cuts off once again the 155 degrees has been reached..much more that 155 degrees the clothing is very likely to combust and catch on fire.
Please reply and let me know if your having a dryability issue with your dryer or where you just concerned since the flame went off??
GENE
Sep 05, 2011 | Kenmore Dryers
I have a kenmore ultra fabric care heavy duty 90 series soft heat i will not come on hum not nothing
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 28, 2011 | Dryers
My dryer won't heat up at all. Model #96575100 Heavy duty 70 series soft heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 07, 2010 | Kenmore Dryers
Heavy Duty Plus "old Dryer" making a loud clunking noise, still heats and dries?
that sound is a bad drum wheel,the drum has 2 back wheels that the drum rides on
May 03, 2010 | Kenmore Dryers
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
remove screw at each end of console. pull & flip back out of way. remove top, remove bottom panel, slide putty knife to release both retainer clips. remove screws to remove door panel assy. remove belt, remove drum. remove motor clamps & remove wires from motor conector.good luck.
Aug 07, 2008 | Dryers
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
Kenmore 62722 Electric Dryer Logo
150 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
