Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
I replaed the convergance chips and still have a red shadow on my sony 51 inch projection tv
    Top Expert:
  • Sony Master
  • 14,553 Answers
This set has two 5 amp fuses on power board that feed the convergence circuit, did you test them?
I needed I can provide photo of that board, fuses are pico fuses and not glass.
Let me know and I will be happy to help you.
SD TECH
Posted on Nov 06, 2010
I have a sony kp-51ws510 projection tv, i replaced the convergence ic's and a pico fuse and then reset the convergence. The tv looks good except for a green shadow on lettering, also on the convergence...
Did you check the two pico fuses on the G board? Usually at least one will blow when the original ICs failed. I am attaching a pic that shows the 2 pico fuses on the G board.
Jul 08, 2011 | Sony KP-51WS510 51" Rear Projection...
My 65 inch sony tv half the screen is having colors like 3 d
Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless.
Feb 20, 2011 | Sony KP-51HW40 51" Rear Projection...
We own the PT51HX41 51 inch rear proj. We are getting a green and red glow around all pictures and wording. Are the bulbs gone or do they need to be adjusted...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors.These parts on the tv convergence board are dead,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 05, 2010 | Panasonic PT-51HX41 51" Rear Projection...
My TV looks like it had permanent 3-D. Red Ghost
hello it sound like the convergance ic may be the problem these chips sit behind the tuner board connected to a metal frame called a heat sink they are soldered in. also you will have to check the resistor in front of the chips also check the 2 capacitors at either end it would be best to get a quote from and engineer good luck
regards
shaun
Jul 10, 2010 | Sony KP-51WS510 51" Rear Projection...
Red shadow
Ur tv have a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.All these parts must be change to solved convergence problems.The shop will cost U $300-350 for parts and labors.
May 26, 2010 | Sony KP-51HW40 51" Rear Projection...
I have sony model KP51WS510 with a red and green shadow also the color is off
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 14, 2009 | Sony KP-51WS510 51" Rear Projection...
RCA projection is having color shadows and blurred picture.
Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
May 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
Sony kp53v75 TV with blue convergence off right by half inch
it is a convergence problem u may have 2 replace conv ic's and some resistors
May 11, 2009 | Sony KP-51WS500 51" Rear Projection...
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS500
the tv needs to have a convergence done on it to realign the picture..the colors have to be set a certain way or it will show shadows and it will only get worse
Jul 11, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
498 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
