Question about Mitsubishi WS-65907 65" Rear Projection Television
So I have the same mitsubishi TV. It has been awesome until now. I too cannot turn it on. We had apower failure a couple days ago and it hasn't been able to turn on since. The fron green light just blinks on and off continually at a very fast rate. I unplugged the tv for about 5 mins and then plugged it back in, samething. Tried pushing the menu and device buttons at the same time to get an error code. NOthing, just continuous flashing of the green light. Not sure what that means. Any one have an idea? Thanks,
  • Paul Castillo Nov 08, 2010
    I will be checking both of these items. Thank you very much for your comments and help. I will let you know if these things work.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Yes, I know problem.
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Nov 06, 2010
Wont turn on
There are so many reasons for this fault. It will be best to contact any service technician.
Jul 24, 2013 | Mitsubishi WD-73737 73 in. HD-Ready TV
Just wont print apower failure 10 days ago
Model not mentioned..If its Inkjet printer might be cartridges are dried up due to non caping of print heads.. Remove cartridges clean manually with the help of solvents.. fix back then try..
Jan 30, 2012 | HP OfficeJet Office Equipment & Supplies
I have a mitsubishi ws-65313 projection tv i was waching it and went black now its not working the green light is on but tv isnt working and i try to turn it off and the ligth still on i push the botton...
Hi. i believe this to be either of these three problems.
1. Power: it could be that there is a problem with the power electronic element(s). the solution is to go see an engineer.
2. Screen: if the television uses LCD display, it could be a problem with the liquid in it. Solution is to see an engineer.
3. Sleep mode: the TV could be in sleep mode which makes the screen go blank until removed from sleep mode. Solution is to read the TV's users manual to see how to wake a sleeping TV. Get back.
Jul 15, 2011 | Mitsubishi Televison & Video
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
MITSUBISHI WS-65807. TV WON'T POWER ON AND PICTURE WAS NOT ALIGNED PROPERLY.
Good Day;
Your TV has "poor" connections on the Convergence IC's. Please get repaired B4 you have total part failure and more costly repair.
Good Luck, big IRISH.
Sep 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Black screen and no sound
I realized that there is a 90 day warrantee on parts and a 30 day limited warrantee on labor for the  repairs that were done. As I stated, the original problem was the picture shrinking after a few minutes of the set being on. The repair firm took my control board with them. When they came back to install the repaired control board in my set there was a load spark during the installation, after which I had a black screen and no sound.  The repair firm took my set them and installed a "CAP Kit", a STRM6511, and a "D1881". The set worked perfectly until two days ago.
I called the repair firm an they are coming out this Thursday to check out my TV.   I am hoping the problem is related to the failure of one of the parts installed to fix a similar problem which occurred after the sparking incident.
Mar 31, 2008 | Mitsubishi CS-40505 TV
Mitsubishi model# wd-62327
you have identified the problem good,
but you could specify the problem a bit accurately
:the possibilities of your problem might be because of.
1.fault in the circuit
or
2.problem in the display of your tv.
Dec 07, 2007 | Mitsubishi WD62327 TV
Mitsubishi 65 inch Diamond rear projection
Sounds like your control unit has going down. its the big silver box in the rear to the left of the set.
Oct 28, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65907 65" Rear Projection Television Logo
372 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
