Question about Maytag Washing Machines
I have a maytag LAT9706AAE Washer the motor does not spin on the drain cycle. I changed out the lid switch, disconnect the drain pump to ensure it wasnt a belt issue or a drain pump issue. The motor is just not spinning. This is either a timer or motor issue anyone knows how to rule out either?
  • 219 Answers
SOURCE: maytag sav365zaww agitates straight through wash
would say it would be the timer if it was the lid switch it wouldnt vspin or agiatate
Posted on Mar 18, 2009
Maytag317
  • 1136 Answers
SOURCE: Goes through cycle, but doesn't drain. Will drain manually
Hi, Sounds like it could be timer. Does the timer advance to the off position? There could be a partial plug in the hose or pump also. You can add water again and then go to spin cycle. Lift the drain hose out of the drain pipe just enough that you can see the water flow. You should see water draining out with a bit of force and the stream should be the sizt of the drain hose.
I hope this helps you. Please let me know if I can be of more assistance.
Thanks
Vic
Posted on May 11, 2009
  • 14 Answers
SOURCE: Washer won't drain and spin. replaced timer, lid
HAVE YOU CHECKED BRUSHES IN MOTOR
Posted on May 15, 2009
mgprice
  • 744 Answers
SOURCE: NO HOT WATER MAYTAG WASHER Model # LAT9706AAE
replace the dual inlet valve located in the rear of the machine. have included a link to help you...you can also purchase the part from the same link. http://www.partselect.com/repair.aspx?appliance=washer&part=replace-water-valve
Posted on Jun 23, 2009
  • 1341 Answers
SOURCE: Maytag Washing Machine Model LAT9706AAE Won't
Check at the back of it,the rubber belt may have become loose or sometimes slips off it course and may need re-fixing....
Posted on Jun 26, 2009
Hello, I have a Maytag Bravos MVWX550XW washer that will not rinse or spin, only wash. The drum moves. I replaced the washer inlet valve, did not fix the problem. Removed the lid switch assembly...
hi Melanie.
this is all i could find out.
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
How to Drain Washing Machine That Won Drain Family Handyman
What is wrong with a washer that does not spin? If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle
Washer Doesnt Agitate or Spin
Maytag Washing Machines will not rinse or spin Google Search
Dec 12, 2017 | Maytag Washing Machines
WON'T PUMP DOWN OR GO INTO RINSE AND SPIN CYCLE
what about your lid switch?...have you checked it already?
tnx 4 using fixya,
drcool
Sep 27, 2008 | Maytag Neptune FAV6800A Top Load Washer
Maytag Whirlpool Super Capacity Ultimate Care Washer, it goes through all the cycles except the spin cycle. Will not spin.
Most likely the lid switch or the motor coupler. Is it just doing nothing when time to drain and spin leaving it full of water? If so, replace lid switch. If it's pumping water out and you hear motor running, but it's not spinning, then motor coupler is most likely broken. In second scenario, also could be clutch or other transmission problem.
Oct 31, 2017 | Whirlpool Washing Machines
Maytag washing machine mah5500Bmodel# put on spin cycle drains out water but wont spin basket
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging
Feb 20, 2011 | Maytag Neptune MAH5500B Front Load Washer
WASHER WILL WASH ON ALL CYCLES, BUT WILL NOT DRAIN OR SPIN ON EITHER CYCLE
If the timer advances normally thru the spin and drain steps of the cycle you selected, than the problem that would cause neither spinning or draining, is the wash motor is not reversing. The motors is a two direction motor. It spins clockwise for normal agitation, but counterclockwise to engage the wash drum clutch and operate the drain pump. I would ask you to check for motor sounds at all during the spin and drain cycles. The pump reversing in the spin or drain cycles can be a function of the machine's lid safety switch, or if not the motor switch or timer contacts. The lid switch is first thing to check here, for sure! If the machine seems to stop running when it comes time to drain or spin, the lid switch is your best bet!
Hope this helps.
kcomp1863
Jan 16, 2011 | Roper RAS8445KQ Top Load Washer
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
The washer will not drain
What is the brand of your washer mostly of the washer does not drain have problem of this following parts, so you need to check this.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models). The lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine.
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Jan 25, 2010 | Maytag Washing Machines
Final spin cycle issues
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
HOPE THIS MAY HELP YOU;
Regards,
VOTIT
Sep 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
HELP!!!!!!
Before spinning, washer draining water aut & than start spinning,,,,if motor runing without drainig water, chek the belt, if belt is OK,and runing pupm, chek the pump,,,,disconnect hoses and clean pump... if washer do not draining & spinning, replase lid switch..... If you need instruction how to replace lid switch, i will post you instruktion....
Sep 01, 2007 | Maytag Performa PAV2200
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
