Question about Velodyne CT-120 Speaker
My ct-120 is humming how do I get it to stop?
  • 3 Answers
My CT120 just started doing this and replacing the 2 large capacitors in the power supply section of the amp fixed it.
Posted on Nov 08, 2013
Found a used Home Master KFF6 Drill Press; thought I scored big when I got it for $50. Motor hums, spindle and chuck don't turn. Can I troubleshoot and fix myself, or can I get it repaired in CT?
The humming motor is that it could not get a turn direction because of only ac and a bad centrifugal or start capacitor if it hums try to turn it clockwise on the chuck to see if it will run .
May 13, 2016 | Drills
How to wire a 480 3phrase 100amp panel to a 75kva transformer to a 208/120 panel
A humming transformer doesn't always mean time to replace. Get some shellac and heat it up to over 120 degrees and paint it on the core frame.
Jul 04, 2014 | Kitchen Ranges
On Kenwood CT 2050, tape speed varies near end of reel and stops prior to end of reel
Many cassette units have trouble handling 120 min tapes. You seem to have taken care of some of the problem areas but in my experience I would suspect the belts have stretched or aged. If this an older deck, the motor may be weakening. It can be the source of the problems you describe
Sep 21, 2012 | Kenwood CT 2050 Stereo Dual Cassette Deck...
Humming noise when powered up
My CT120 with the same problem was fixed by replacing the 2 large capacitors in the power supply section of the amp.
Dec 17, 2010 | Velodyne CT-120 Speaker
Carver CT-28v Tuner preamp - Has a hum/buzz (soundls like a ground loop) that is heard as soon as the unit is turned on. Does not increase with volume, just stays the same and is continuous. Changing...
Reverse the polarity of the AC plug and try it. Is there a headphone jack on the preamp? Try headphones with the preamp standalone without the amp attached.
Are you sure the preamp is the problem? I assume you also have an amp or you wouldn't hear anything. Power up the amp with nothing but speakers attached. Hum??? It's in the amp. No Hum? Attach just the preamp with no external components. Hum now? It's the CT-28. Turn it off an exercise every switch and knob throughout its range numerous times. Try again. Still humming? Manipulate source selections, Tape Monitor, everything.
Nov 19, 2009 | Audio Players & Recorders
When the air compresor turns on the first time it runs good when we torn it off and try to restar it, it will not turn on
the switch on most air compressors have a low start and stop rating most run at 90psi low and 120 to 130psi off depending on your unit. if you turn on your unit and if it humens, than check the pressure valve mounted on the tank at the end of your feed line. if no humming check your switch
Oct 14, 2009 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Velodyne CT-120 Speaker Logo
82 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Matthew Spark
Matthew Spark
Jerry Greenberg
Jerry Greenberg
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
