Look up Sanyo Appliances on the internet. When you get to the Sanyo Appliance section, type in you product by name and number. When the item is found, look for replacement parts. Once you find the part you need, simply go from there.
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
hi there......you havent stated the manufacturer of your fridge...however obtaining shelves for your fridge should be no problem..provided you have the model and serial number and if possible the product code.(a) contact your local your local domestic apliance repair/spares shop....(b) go online to the manufacturers web site...(c) go on line to google enter your fridge details this will provide you with information where to obtain your parts...
the door shelf may be a different issue...if the shelf is part of the door lining then you will need a relpacemant door
you can go to sears .com click on parts, put in your model number and get your part also you can try repair clinic .com,let me know if you find it,thanks-mike
The refrigerator door seal is being broken when you open the freezer door? Sounds like the rubber magnetic strip needs to be replaced on the refrig. door, they wear out after a number of years.
try dismantling the shell and check for any jammed object or broken pieces that might cause the door jamming. if it is a matter of a stuck object that somehow got there, you can remove it and hope for the best. otherwize, you will have to replace the broken pieces, or the whole part.
