Question about GE Refrigerators
Have water to the ice maker, but not to the door of our pgss5pjxc ss. I lowered the interior temp to see if that would help, but no luck.
  • jmoar5 Nov 06, 2010
    That's what I was afraid of. I took the back off and found the entire line is empty from the valve on, so i guess it's for sure not frozen in the door like someone told me.
    thanks
  • 2,382 Answers
Hi, you have a bad water inlet valve which you need to replace before water can get to the door...
Posted on Nov 06, 2010
  • Tunde Autos
    Tunde Autos Nov 06, 2010
    O.k, you can now accept and rate the solution....
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a french door refrig with two ice makers. I cubes seem to be wet in door when crushing ice. Also in bottom ice maker the cubes are stuck together in tray in one clump. I lowered temp to -4 but it...
You need to check the door seal. If you place a $bill in the door it should have resistance all the way around as you pull the bill through. It may just be that the doors need adjustment.. If you are able to maintain -4, the ice maker heaters may not be working properly. Also, you want to check the water valve to make sure that you are getting cold water to the icemakers as hot water coming into the fridge can also cause this. If this is the problem, you can use a longer coiled line for the water inlet valve.
Sep 01, 2011 | Samsung Refrigerators
Eletrolux side by side. temp problems. no water on door and at first when the freezer door would close the ice maker would kick on and ice would start dispensing.
Sounds like the touch pad has a jammed button or is shorted , if it dose not release by depressing a few times firmly, the touch pad on the door may have to be replaced. The temperature problem may be unrelated or the ice maker door flap may be remaining open lowering the temperature. Hope this helps.
May 02, 2011 | Electrolux Refrigerators
Will not make ice, freezer temp is high, can not control the temp
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 31, 2010 | Frigidaire PHS39EHSS Stainless Steel Side...
No ice being made. water supply for drinking is OK. Model is about 3 years old. question: why no ice. does the automatic shut off arm control the water flow?
Well first of all you can check to see whether the ice maker has been turned off, Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat. Please reply if you need more help or information.......
Good Luck!!
Thanks
Dec 29, 2009 | LG LFX25960ST Stainless Steel French Door...
My ice maker doesnt make ice i have checked all the obvious stuff
Did you check the temperature of the freezer? Most ice makers have a temp senser imbedded in the tray/unit . If the temp in the freezer isn't at least 5 degrees (normally on many ice makers) the ice maker won't operate. This is one possible cause. Other causes could be no water to the tray, the timer motor defective or stuck somewhere in its cycle, or the bin arm is up in the off position. I hope I was of some help! Good luck!!
Nov 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker Has Stopped Making Ice
Hi: I didn't see the simple first solution to try in your list. The ice maker is thermally protected. It won't make ice until the freezer is at 0degrees F. Set your freezer lower in temperature. It may seem cold to you but it has to be at 0degreesF. Frozen at 32 degrees wont cut it. Please don't open the door every 5 minutes to see if it's made ice, as it will raise the temperature. It appears in your question that you listen for the ice to drop. That's the right way. Give it a day to drop in temp. before resetting the temp. This is a free try before you have to call a technician. I hope this helps, Jeff
Jun 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Oct 10, 2008 | GE Refrigerators
Ge sis by side
Howdy do!,,,this happened to my GE side-by-side,,,I found that the water line in the door was frozen,,,I lowered the temp in the freezer by just one number,,,then warmed up the door with a hair dryer,,,,when the water line thawed out enough to work a small piece of ice came out of the line and went in my glass. Good Luck!,,,,Pete.
Sep 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
