Question about Sharp R-9H84B Microwave Oven
The lamp in my R-9H84B Sharp microwave has burned out--or at least there is no light in the cavity when I turn it on. I can't find anything in the manual about how to replace it. Do you know if it is replaceable . . . and, if so, the model number of the lamp, and how to replace it? Gary
  • garyschuldt Jan 12, 2011
    Thanks for taking the time to answer this question.
    It sounds like you've done this before . . . and that's the kind of expertise I was looking for. The oven is positioned such that I can only easily see the front of it and a little bit of the left side (left when facing the front door). So I wanted to be 99% certain of the solution before I pull it out of its mounting and disassemble it. We use that thing every day!
    I will accept your answer.
    I didn't realize I'd be offered this opportunity to post a note to you.
You can order the lamp from Sears here.
Replacing the burned out lamp is fairly straight forward. Since I don't want you to kill yourself, please unplug the oven before doing anything else. Remove the four black screws from the sides of the oven (two per side) and the seven screws on the back unit holding the cover on. These back screws are easy to find as they are the ones at the edges of the back, two per side and three across the top.
Now, standing behind the oven, slide the cover back a couple of inches so the cover taps clear the frame. Then, grab the bottom edges of the cover on both side, gently pull them away from the oven frame and lift to top off. As soon as you have the cover off, the lamp will be obvious - right on top, toward the front.
While you are replacing the lamp, you may want to clean the glass - I do that whenever I have the cover off because that window tends to get dirty over time and interior cleaning. The screw to remove the frame holding the glass is inside the oven, on the top, front right of the oven. Use non abrasive scrubbers and cleaning solution because you don't want the glass to crack on you in the future. You might also want to vacuum out any dusty bunnies that you find.
Assembly is pretty much the reverse except that you want to put the side screws in first. You want to do this first because you must make sure you have the cover tabs correctly slid into the frame or the front edge will not be correctly pulled into the front trim. I found that pushing the sides in while sliding the cover forward does the trick. After you have all the screws back in, plug the oven in, pop open the door and the light should come right on.
Posted on Jan 10, 2011
Sharp carousel ii microwave
Turn table does not turn , sharp convection microwave R-9H84B
Can I fix this myself? or do I need to have it serviced?
Dec 06, 2013 | Sharp Microwave Ovens
Replaced 20A fuse - now display blinks
Here is the parts page for your unit with an exploded view and parts list
http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R-9H84B/0958/0123245/P0050209/00001 It is possible the switch is bad the look at part number 1-6 hope this helps.
Nov 08, 2013 | Sharp R-9H84B Microwave Oven
I have a sharp microwave convection oven model R-H93 and when I turn it on for only 3 seconds the light from the wave guide cove blinks viiolently and the who oven makes a loud electrical sound and a...
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the metal of the cavity is chipped or charred, you need to clean it, sand it shiny, then clean it squeaky clean again.
Then you can get high temperature appliance paint in spray or brush-on form from local appliance part stores or places like Wal-Mart and Lowe's.
I would suggest you let it dry overnight with the door open before using the oven.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
You can order Sharp parts from Encompass here or call them toll-free at 866-779-5835.
Recheck your full model number. You have an incomplete one above.
Jun 07, 2012 | Sharp R-9H84B Microwave Oven
What is the wattage of model R-9H84B
That model had 900 watts of microwave power output, and the convection outpout was 1450 watts.
Jun 18, 2011 | Sharp R-9H84B Microwave Oven
Need part # for magnetron for sharp model R-9H84B. also supplier.
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Apr 17, 2011 | Sharp R-9H84B Microwave Oven
The light dows not work on my Sharo R254 microwave everything else is working. I gather all I need to do is change the light bulb but cannot find in the manual how to do it and what light bulb to...
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Mar 10, 2011 | Sharp R-254 Microwave Oven
R-209 Microwave : How do i change the light bulb pls ?
Hope this helps.
Feb 15, 2011 | Sharp Microwave Ovens
Need instructions for replacing light bulb in Sharp Microwave Oven Model R430EK
When you have the new lamp to hand, so you know what you are looking for, remove from the mains supply and remove the case. The lamp is generaly near the vent or transparent poit in the cavity, that used to let the light shine through.
Remove the old lamp and fit the new one, taking care not to leave any wire ends free.
Jan 05, 2011 | Sharp Microwave Ovens
Sharp Microwave/Convection vintage 1994, model # 9H84B turntable has suddenly stopped turning. When functioning, table could start rotation in either direction.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 07, 2010 | Sharp Microwave Ovens
Sharp R-9H84B Microwave Oven was working normally
There should be an oven thermal cutout (part # RTHM-A048WRE0) on top of the oven chassis / cooking cavity. It will be on the left side top.
Also, there is a 150 degrees C magnetron temperature fuse (part # QFS-TA013WRE0) mounted on the side of the magnetron.
Lastly, there is a line fuse, probably located on the door switch mount between the switches.
All of these should read "closed" or virtually zero ohms.
The fuse and magnetron temperature fuse may be available at local appliance parts stores, but you can order parts from Encompass here or you can call them toll-free at 866-779-5835.
The part numbers above end in zero, not "oh".
Let me know if you need more help. Otherwise...
Aug 08, 2009 | Sharp R-9H84B Microwave Oven
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
