Question about Whirlpool WTW5300SQ Top Load Washer
I have a whirlpool washer, model WTW5300VW2, Serial #: CY4720592. It has 4 water temperature settings. The hot setting results in hot water, and the other three produce cold water. Suggestions?
  • dhoward936 Nov 07, 2010
    What switch are you refering to? The link associated with the word is not working.
    Manual refers to a Water Temperature Switch. Is that it? If so, where would I find it on the machine?
    President:
  • 1,891 Answers
This washer uses a special type of valve ( water inlet valve ) is has a thermistor . that regulates the tempt it's part # is w10144820 and this should correct your problem . mm / hope this helps. ..feed back pls mm
Posted on Nov 08, 2010
  • Whirlpool Master
  • 8,220 Answers
In the past reports of a bad water temp switch have been reported. I would suggest replacing that switch. Replacing it is easy: lift the tab and twist the switch to release it after removing the knob. To get to the switch you must flip the controls. I have videos HERE
Posted on Nov 06, 2010
I have a Whirlpool washer GHW9150PW0 and it always washes on hot water, no matter if I set the temperature on cold. I turned off the hot water faucet and still the wash comes out warm. What is the problem?
these washers sense the water temperature that comes in to them and automatically adjust the temperature by turning on the hot and cold valve on make sure both your water valves on the wall are on all the way and water is coming out of each
Aug 19, 2010 | Whirlpool GHW9150 Duet Washer
Whirlpool WTW5300VW2 washer hot water pipes shake during fill
Good day,
The only test on the water valve itself, is to replace it. The term is
"replace with a know good part", but may or may not work.
It is very possible you mght need a plumber to install a riser on the hot water line somewhere betwen the tank and the line going into the washer. The riser creates an air cushion in the line that is used on many issues much as you described.
It could well be best to call a few quality plumbing companies, to see if they have dealt with that issue.
Jul 13, 2010 | Whirlpool WTW5300SQ Top Load Washer
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washing machine water not hot enough
This so called "energy saving" ...That's why they build in this nonsense. Some dumbo in some office somewhere just thought it up thinking that will save the energy. I fact ,that way I have to wash same stuff twice because water is not hot enough ...
Apr 07, 2010 | Whirlpool WTW5300SQ Top Load Washer
I can't set my Neptune washer temperature to cold water wash. I press the HAND WASH button which originally used cold water but now it stays on hot water (highest temperature setting). the arrows where you...
you need to call your parts store or the factory number in your book,give the model and serial number to them and order the console,the touch pad is damaged and they sell you the whole top console on the washer
Feb 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water setting temperatures are off
It would say that it should be under warranty.But this model has parts that are no longer availible. Here is my guess, you have a bad switch.
Part number PS1491292
on this web site http://www.partselect.com/
Please rate solution
Aug 24, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washer wont allow cold water
Mixing valve should lock out the hot water when on the cold water setting. Either your hoses are crossed, or the mixing valve is flipped. To see if one of these is true, try it on a hot water setting to see if cold water comes in, or try just swapping the water hoses.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool WTW5300SQ Top Load Washer Logo
496 people viewed this question
Dan Webster
Dan Webster
Sal De
