Question about Hotpoint HSS25GFP Side by Side Refrigerator
HOTPOINT FRIG COMPRESSOR
I HAVE A HOTPOINT FRIG THAT IS PROBABLY 35 YEARS OLD.IS IT NORMAL FOR THE COMPRESSOR TO BE QUITE HOT ALL THE TIME?
  • Hotpoint Master
  • 3,463 Answers
Yes it is normal for them to run hot, a lot depends on the ambient temp.
If it is working normally then you have no worries, but if it is running continuously , then there is a problem with it.
Make there is adequate ventilation, and that the thermostat is set correctly.
Posted on Jan 04, 2009
Hotpoint fridge makes clunk-clunk-clunk noise when it shuts off
You need a new compressor. Probably time for a new frig.
Nov 18, 2011 | Hotpoint Refrigerators
Compressor in the back is hot
Good day,
It is normal for a compressor to run hotter than normal when it is going thru it's pull down cycle.
One, it is working harder than normal since the interior is still warmer than normal.
As well, at the beginning, since the machine is trying to get to normal temps as well as cooling the walls, it will run excessively if not all the time.
Waiting 48 hours would be prudent to make a judgement call.
The compressor should be warm, but since by then it should be shutting off and on it will tend overall to be cooler.
If it reaches normal operating temperatures and cycles off and on, I wouldn't worry about it.
Jul 21, 2010 | Danby Compact Refrigerator DCR-101W
The compressor wont start back up. The fan runs
Unplug. Then feel the compressor by hand. Is the shell really hot? go get some ice and cool it off or leave unplug for a day. after cool off re-plug to see if compressor kicks back on. if it does make sure it is clean inderneath otherwaise it will do the same thing. if it does the same thing (within 24-48 hours) plan B. Replace the relay on the compressor (like $10-20 bucks at appliance part store or get it from sears. That should do the trick. Make sure it is clean underneath (if it is dirty thats probably what caused the problem) if you replace the relay and still doesnt work then you need a new compressor. if you paid a lot (over a $1000) then it will be worth fixing it. (its gonna cost between $300 - 500 to fix) make sure you get a written warranty most importand at least 5 yrs.
But if you frig has alot of wear and tear and not worth alot then toss in garbage. just to take a look at a frig that does have a bad compressor is like $80 and thats ridiculous ( i only charge $35 and people still complain, oh but you didnt do nothing though...come mon!!!!! ahhhhhhhhhhhhhhh!!!! ok i am alright...
hope i was helpful (you owe me $35 jk)
Mar 29, 2010 | Refrigerators
Moved frig then plugged in and ran for several days then quit, then two days later started again and then a week later quit again? Frig is a ten year old side by side Kenmore about 21 sq feet, ice maker...
If you didn't give it enough time for the oil to settle back in the compressor that could be the problem. I would try leaving it off for a day to see if it will settle down and run better.
Sep 30, 2009 | Refrigerators
Divider strip between fridge and freezer is hot
First take the grill off at the bottom under the doors look at the grate under the frig That is your condenser it will probably be covered in dust clean it off the see if you can fill air blowing under the frig there is a fan under there that keeps that coil cool and it runs around the door to keep condensation from build around the doors if no air is blowing take the back panel behind the Frig and there should be a fan running if the compressor is running this will also cause the compressor to over heat and will not cool as well but it might just need to be cleaned Good luck
Apr 03, 2009 | KitchenAid KSRG22FK Side by Side...
Whirlpool refridg side by side
This sounds like the compressor is bad. The clicking sound is the start relay trying to start the compressor and cannot. You stated that it was only four years old. Check the warranty for your frig. Most carry a five year warranty on the compressor.
Nov 10, 2008 | Whirlpool ED5FHEXMQ Side by Side...
GE HSS25GFP not cooling at all
May be a problem related to the compressor. Click may be the overload protector on the compressor tripping. If it is a problem with the compressor it should be covered by warranty if it is only three years old.
May 14, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
148 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
