Question about Gateway MX8738 Notebook
Gateway MX8738 will not charge. I have tested the power output at the connector and it is 19.5Volts. I have wiggled the connector and still cannot get the laptop to charge. I have tried it with and without the battery and no power/charge. It appears that no power is coming through the power connection.
  • 2,567 Answers
Seems that the power receptacle in thelaptop itself is either damaged, or its solder points on the motherboard has gone loose. You will need to fully disassemble the laptop in order to get access to the motherboard & replace or re-solder the power receptacle.
Posted on Nov 06, 2010
2002 elantra no power to wipers radio head lights and heat
Please check for codes in the OBD system. Check Battery and Charging System. If no codes perform following test procedure.
Tests/Procedures: 1. Check the Black power connector in the under dash fuse box. Wiggle it with the lights on and see if they malfunction.
2. Wiggle the wiring harness from the ignition switch around the steering column with the lights on and see if they malfunction.
3. Monitor the key on battery voltage from the ignition switch at terminal 3, Red wire at the ignition switch to terminal 3 of connector I/P-E in the under dash fuse box.
4. See if the vehicle has any aftermarket accessories installed that may be tapped into that Red wire from the ignition switch to the fuse box.
Potential Causes With OEM Direct diagrams, components, TSBs, and R&R procedures
Ignition Switch
Output Speed Sensor (OSS)
Power Connector
Radio Wiring
Steering Column Wiring
Apr 07, 2015 | Hyundai Motor 2002 Elantra
Need a mass storage controller for gateway mx8738
The mass storage controller actually refers to your media card reader.You can download the "Mass Storage Controller by going to this link: http://support.gateway.com/support/drivers/getFile.asp?id=21836&dscr=Windows%20XP%20and%20Vista%20(32/64-bit)%20TI%20Media%20Card%20Reader%20Driver&uid=292768049
Download and follow the prompts.
Note: This should be compatible for both 32-bit and 64-bit OS XP and Vista only
Jan 06, 2011 | Gateway MX8738 Notebook
Remove bios password gateway mx8738. replacing HD don't know the bios password
Remove your cmos battery, and if there are jumpers by the battery, this should clear the bios.
If not just leave the battery out for a short while
Aug 20, 2010 | Gateway MX8738 MotherBoard - DAPA6AMB6D5
Gateway MX8738 Laptop won't power on. The power adapter is putting out the correct voltage, but the computer is dead - no sign of life. This happened once before - repaired under warranty. This time I'm on...
Sounds like your power jack may be faulty or bad connection to motherboard unfortunately. The only way to truly find out is by disassembling the laptop. You'll have to do this at your own risk of course, and test the terminals at the power jack to see if you are getting power through them, if you are, then the trouble is deeper in the motherboard. If you are not, then here is a good article on how to fix the power jack:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Good luck.
Jul 21, 2010 | Gateway MX8738 Notebook
LAPTOP WILL NOT TURN ON . GATEWAY 8738. NO LEDS LIGHT ON FRONT. DOES NOTHING BATTERY IN BATTERY OUT. WILL NOT TURN ON. I SUSPECT MOTHER BOARD
You could well be correct but just to make sure.
You need to beg, borrow or steal another known good power supply/charger unit and see if that works. You see if yours in faulty, its not charging the battery or supplying power to the laptop.
If nothing glows after that it could be the charger circuit on *********** board or just the power connector on the motherboard .
May 11, 2010 | Gateway MX8738 Notebook
MY GATEWAY MX8738 WILL NOT READ SDMC MEMORY STICK FROM CAMERA...ANY FIX???? USING VISTA SP2
try the card on another computer to verify that it is a computer problem
Jan 17, 2010 | Gateway MX8738 Notebook
Gateway MX8738 power adapter problem
Does the DC jack on the laptop wiggle or feel loose?
If that's the case then eventually the jack will go bad will have to be replaced. Most computer shops charger around 60-100 for the repair.
If it's the charger itself then just replace it with an ORIGINAL from eBay.
Hope this info helps and if you need more specifics just let me know.
--RescueTechLA
Nov 29, 2009 | Gateway MX8738 Notebook
Hello I have a gateway mx8738 laptop operating system not found
Is this happening when your using a DVD disc to watch movie? Then when it boots back up it trys to boot from your video DVD. It wouldn't do that if you take the DVD out before it boots. But, that is only is your using a DVD or cd. If not then you might want to change your video software. The computer is probably still down when it's booting up again and can't find OS. Hope this helps you!
Sep 17, 2009 | Gateway MX8738 Notebook
Gateway MX8738 Notebook Logo
149 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
