Question about Coleman Mach III Air Conditioner
My coleman Mach Rv air conditioner with built in heat strip keeps tripping it's internal circuit breaker when running for any length of time. Just replaced heat strip with new one experienced same issue. I ended up with the fan continuing to run but only cold air comes out of the vents! When I removed the old unit and reset the circuit breaker it too worked again. Have no idea what is causing this to happen. The airconditing part of unit works just fine??? HELP! Ron
    Problem Solver:
  • 16 Answers
There should be an overload protection device in series with the low voltage wiring(t-stat wiring) Is it resting on the heat strip or too close to it? It is a saftey device to shut off the heat strips if the fan quits or a fire in the heat strip section. check that or by pass it, if it stays running then ur thermal protector is bad, couple bucks at the parts house.
Posted on Nov 06, 2010
Brand new Coleman Mach 8 RV aircon worked yesterday but today blue on light just keeps flashing and no compressor working
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
Nov 07, 2015 | Coleman Mach III Air Conditioner
Coleman mach rv ac unit tripping breaker
If it trips the circuit breaker as soon as you turn the FAN on, suspect either a bad fan motor or a failed fan motor start capacitor. If you are able to turn the fan on but the circuit breaker trips as soon as the COMPRESSOR starts, it is possible that the compressor is seized.
If, on the other hand, the unit is tripping a GFCI (Ground Fault Circuit Interrupter) breaker or GFCI utility outlet, it is possible that neutral and hot are reversed at the outlet into which the trailer is plugged (happened to me this year at an RV park).
May 14, 2015 | Coleman Heating & Cooling
Coleman Mach III RV AC
Sounds like possible fan capacitor failure. If your not familiar with capacitors, please find someone who is, as they can give a fatal electrical jolt if not handled properly.
Jan 26, 2013 | Coleman Mach III Air Conditioner
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Aug 18, 2011 | Coleman Mach III Air Conditioner
Hello , this is Bobby and I have a Coleman Mach rooftop air conditioning unit Model # 8335B8964 when I turn on the unit ,it throws the circuit breaker . I have replaced the starting capacitor and the...
Here's a link to a service manual, with step by step tests to determine whats wrong. I'm thinking compressor shot, but this should confirm, and or help you determine for yourself. Be careful with those capacitors eh !! Read warning in service manual.
http://www.rvcomfort.com/pdf_documents/1976141_copy.pdf
Oct 19, 2010 | Coleman Mach 15 Air Conditioner
Air conditioner blows the breaker when starting up
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 27, 2010 | Coleman Mach III Air Conditioner
Trips breaker and will not cool or heat
Disconnect compressor leads and tape them up. Restore power, if the breaker does not trip, than you have a grounded compressor.
If breaker trips again, hook compressor up and disconnect blower, if breaker does not trip you have a
bad blower motor.
Jun 18, 2010 | Coleman Mach 15 Air Conditioner
2 year old Coleman Mach III tapping and not blowing cold air:
Make sure the condensor fan is blowing through the condensor on the roof. It sounds like the compressor is fighting high head pressures after running a bit.. After so many attepts, or if it suceeds in operating the load trips the circuit breaker.. Make sure the condensor is clean and air is passes through it from the fan. Just for clarifiication the condensor is the coil that gets hot and the evaporator is the coil yat create the cold air. Good Luck, and if you will, let me know how it turns out. Good Luck. Ned
Sep 19, 2009 | Dometic Rooftop RV Air Conditioner
Problem, no heat
The fuse is a 110 volt breaker in your service panel. If your heat comes from the heat strip it is inside of the ac in front of the evaporator. If it is a heat pump thats the the compressor. To create heat the compressor runs in reverse. There is a directional relay operated by the circuit board and thermostat to tell the ac what you are calling for, heat or ac. The heat strip is connected to the circuit board and is also operated on 110 volts. You have one of three problems. Breaker tripped, bad heat strip, bad circuit board. Possibilities, find the heat strip cable and unplug and plug it back in a few times,maybe lost connection. That happens at times because of the warm and cold elimates. The heat strip can be tested by takeing it out and bench testing it with 110 power. circuit board can be checked by use of a volt meter, turn the ac to heat and check the pins where the heat strip plugs in. To chech the heat pump you must go up top, remove ac cover and with an amp clamp find the wires going to the compressor and put the amp clamp on one wire only. Amps should be no more than 7 amps. If it is the compressor is shot. If there is no reading then the compressor is not running. Now you may have a bad capacitor which is up top under a sheet metal cover. They also can be tested with a VOM. You will find 2 or 3 capacitors depending on model. Run and start. Capacitors typically are charged with 370 to 600 Volts. They will knock off the top of your camper. BE AWARE OF THE FACT YOU ARE DEALING WITH 110 VOLTS. IF YOU ARE NOT FAMILIAR OR COMFORTABLE GET SOME QUALIFIED HELP. GOOD LUCK
Mar 14, 2009 | Coleman Mach III Air Conditioner
Wiring Diagram Coleman Electra Heat Mach EL
I need the motor for a mach EL air conditioner. I can not get a model number of the unit or a number off of the motor. Can someone help me. Its about a 1980 built unit.
Mar 29, 2008 | Dometic Rooftop RV Air Conditioner
Coleman Mach III Air Conditioner Logo
228 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
