Question about HTC Hero Smartphone
My htc hero phone will not start up. it completely repeats the boot up process but not finishing the boot process. i have tried the procedure to force my spne into safe mode and it failed. is there a process that i can take to manulally fix the problem with my usb line to a pc? i need a swift response a.s.a.p.. thanks
I have the same problem. There was an update and something went wrong. It installed, but the it just kept stannding on the startup-page. I pushed Back, Home and start, I then pressed menu, and now it's all black. I can't start it at all
Posted on Jan 29, 2011
How to so a hard reset on a htc hero
Please note that all data will be deleted from the HTC Hero as a result of this procedure. This process does NOT delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
  1. Turn the power off. If your HTC Hero is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and release the Power button
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If you selected YES, all data including third-party applications will be deleted from the HTC Hero. Once the wipe is complete, the phone will reboot to its factory fresh state.
Oct 26, 2011 | HTC Cell Phones
Tip
How To Reset Your HTC Hero
<span style="font-weight: bold;">Soft Reset</span><br /> <ol> <li>Turn off the phone, if you can.</li> <li>Remove the battery and wait 1 minute.</li> <li>Reinstall battery and turn on the phone.<br /></li></ol><span style="font-weight: bold;">Hard Reset/Factory Reset</span><br /><span>Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state.<br /></span><span> <ol> <li>Press HOME &gt; MENU, and then tap <b>Settings &gt; Security &gt; Factory data reset</b>.</li> <li>On the Factory data reset screen, tap <b>Reset phone</b>, and then tap <b>Erase everything</b>.</li> <li>Your phone will erase all personal data and restart. It may take a few minutes for the process to complete.</li></ol></span>or<br /> <ol> <li><span>When the phone is turned off, press and hold the <span style="font-weight: bold;">HOME</span>, <span style="font-weight: bold;">END CALL/POWER</span>, and <span style="font-weight: bold;">BACK</span> buttons.</span></li> <li><span>The reset process will start after a few seconds.</span></li> <li><span>When the phone finishes the reset process, press <span style="font-weight: bold;">MENU</span>.</span></li></ol><a href="http://www.htc.com/us/support/hero-sprint/help/tips-and-tricks"><br />Click here for other Tips and Tricks for the HTC Hero.</a><br />
on Feb 15, 2011 | HTC Hero Smartphone
I forgot my drawin pattern on my htc hero how can i unlock it
Factory Reset the phone but it will erase everything from your phone.
To reset the phone using phone buttons
  1. With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button. The reset process will start after a few seconds.
  2. Wait for the phone to finish the reset process and then press MENU.
Oct 23, 2011 | HTC Hero Smartphone
My htc desire will no longer sync with my PC it asks to insert disk into drive E
Your solution
Setting up HTC Sync to recognize your phone
After installing, set up HTC Sync to recognize your phone.
1. From the Home screen, press MENU, and then tap Settings > Accounts & sync.
2. On the Connect to PC screen on your phone, tap HTC Sync and then tap Done. Your phone attempts to find HTC Sync on your computer. Wait for a few seconds for the process to finish.
3. If your phone displays a message indicating that it's unable to find HTC Sync, try disconnecting and reconnecting the USB cable, and then repeat step 2.
4. When the Phone Connection Wizard is displayed on your computer, click Next.
Enter the name you want for your phone, and then click Finish.
Check the HTC Sync icon at the bottom-right side of your computer screen. If it appears green in color, that means your phone has successfully connected with your computer and HTC Sync recognizes your phone
If still no go try this .
Unplug the phone from the PC, restart both the phone and the PC. When the PC is done booting, plug your phone in and see if the autorun box pops up.
still if nogo try this .
you have to select disk drive (when plugged in via notification area) to be able to view the drive in windows and htc sync to use htc sync.
May 27, 2011 | HTC Desire Cell Phone
Sprint HTC Hero w/ google will not boot past first htc screen
pull out the battery and reinstall the battery and before you power it on hold the volume down button while holding volume down also hit the power button when you boot into 2e or 3 e recovery reboot system from there if that does not work repeat the above steps and wipe data before doing system reboot you will loose data you dont have backed up but that should take care of you if you need any more assistance just reply to this goes to my phone thanks
if this helps you please give me a good rating thanks
May 07, 2011 | HTC Hero Smartphone
Im Yasein From Egypt i have HTC TOUCH P3450 Mobile written back movistar Mobile and the Spanish language and I want Windows or English Arabyalmobail works with Windows 6 Professional and I wish you any...
hi yasein, what version of windows is on your pc?
download these two files and extract both
this one is the spl installer which needs to be run on your computer, if you get an error you will need to use the next download on the phone first
http://www.mediafire.com/download.php?sspbx0b1o3dqmtl
this next one needs to be extracted and then copied to your phone and then opened on the phone itself to be installed
http://www.mediafire.com/download.php?dvubl37qzaw2mh0
Please make sure Activesync is enabled (green icon in systray)
and hit ENTER to start...
STEP 1/3......50.......75.....100.
The next step will load a patched bootloader (SPL) on your device
it will make your device temporary SuperCID (seclevel=0), and will
avoid modelID and signature checking when flashing NBH files.
Hit ENTER to continue...
STEP 2/3.....15......25....50....75......100.
Phone screen should now be blank and the activesync icon gray
if not, the loading procedure has failed and you'll have to repeat again.
If all was OK hit ENTER and the standard "PDA Phone ROM Update Utility"
window will start, allowing you to flash patched SPL on your device.
Hit CTRL+C to Cancel or ENTER to continue...
Follow the steps on the wizard to flash the patched SPL, when this
step completes your device will reboot.
STEP 3/3 - Launching RUU, please wait...
Process is finished, congratulations!
If you find it useful don't forget to donate :)
(c)2007 pof - XDA Developers
Hit ENTER to quit.
Hit ENTER to quit.
then follow these instructions
STEP 1/3......50......75....100
STEP 2/3.....15......25....50...75.....100
Hit ENTER to quit.
if you have had success with installing the first file and it has completed without error then you can now download this file
http://andrewloh.com/HTC/New_Blue_Touch_ROM_V4.0.zip
extract all files in it and run the ruu_setup file in there and follow
th instructions on screen. When its finished you will have wm6.1 in
english installed on your phone
May 01, 2011 | HTC Touch P3450 Smartphone
HTC phone in safe mode, can this be fixed
Hi, When you're done troubleshooting problems with your HTC Hero in Safe Mode,
you will need to go through steps to boot it regularly and remove it from Safe Mode.
To do so, turn off the phone. Then while its off, hold the Menu and Power until the phone boots. The Hero should then no longer be in Safe Mode
Start the phone and uninstall apps in safe mode
If your phone keeps restarting, or it starts up but does not display the Home screen, a recently installed application may be causing the issue.
When this happens, try starting up your phone in safe mode. In this mode, your phone does not run any third-party applications. Safe mode allows you to start up your phone successfully so you can uninstall any applications that you have recently installed or which may be stopping your phone from starting up correctly.
To start up your phone in safe mode, press the END CALL/POWER button and hold the MENU button until your phone restarts and displays the Home Screen. You will see "Safe mode" displayed at the bottom-left side of your phone screen. When your phone is in safe mode, follow the same steps in Removing installed apps to uninstall the third-party applications.
After you finish uninstalling the applications, restart your phone and check if the issue is resolved.
Hope it helped.
Thanks for using fixya....
Jan 10, 2011 | HTC Droid Eris by
I have locked my phone & don't know my email address or password to unlock it how can I fix this.
Turn OFF your phone. Take your SD card out not to loose data, then press and hold the "Home", "End Call/Power" and "Back" buttons. The reset process will start after a few seconds. Wait for the phone to finish the reset process and then press "Menu".
Nov 12, 2010 | HTC Hero Smartphone
HTC Hero GPS
try downloading GPS Essentials (free) from the market. It has a tab that shows how many satellites the phone is picking up. that usually is what determines the gps accuracy. also remember that the antenna is at the bottom of the phone. right where your hand holds it. This should not affect it but is good to know.
Mar 24, 2010 | HTC Hero Smartphone
Model id error during boot of the htc hero telus
i would take it back to the vendor and swap it out. you shouldn't get any errors with a brand new phone.
Nov 25, 2009 | HTC Hero Smartphone
HTC Hero Smartphone Logo
195 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
