Question about Lexmark X2500 All-In-One Printer
LEXMARK X2500 UNSUPPORTED CARTRIDGE Brand new cartridges print a few pages and then get this error. Once when i had just printed a page and tried to print a copy of the same file.
SOURCE: ink problems lexmark x2500 printer
lexmark ran out of ink replaced cartridge. still saying i am out of ink and wont print anything
Posted on Dec 04, 2008
  • 66 Answers
SOURCE: Lexmark T62 Error 32- Unsupported print cartridge
Hi Sue,
Firstly, switch on the printer without a cartridge inside. Put in the old cartridge and if you get the Error 32, it could be poor contact. Clean the contacts in the printer (contact with the chip on the cartridge). If you don't get Error 32, there could be a problem with the chip contacts on the new OEM Lexmark cartridge or a faulty chip. As for other brands or remanufactured cartridges, it could be compatible parts they used. The chip and toner wheel have to be compatible.
Good luck.
Posted on Dec 16, 2008
Joed911
  • 4338 Answers
SOURCE: Hello! My Lexmark X2350 today said me: "Unsupported cartridge Install a correct print cartridge." Yesterday it printed very well... but today((( What I must do now? help me !
Follow the steps on how to correct the error from this Lexmark link:
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:487:0:0&docid=ENUS24096
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 11, 2009
guide2u
  • 461 Answers
SOURCE: "unsupported cartridge"lexmark X2470
reinstall the cartridge. Turn of the printer leave it for 10 minutes and restart again. If you still have more problem check below link, youmight find some useful info.
http://pc-and-peripheral.blogspot.com/
Posted on Oct 19, 2009
  • 320 Answers
SOURCE: Error 32 Unsupport Print Cartridge Lexmark T630
on the inside of the top cover on the left side when the door is open there is a little switch youll see a little metal tab 5/16'wide push on this and see if the error clears. if it does this can be adjusted. if not pull the cartride out there are two sensors on the right inside one close to the front this is an optical sensor blow this out with canned air if you dont have an air compressor. then further back inside there is a two pin sensor make sure that if you push in on these that they dont stick. next there is a smart chip on toner caartridge that lines up with those pins when its installed clean these contacts. doing all of these things usually geets rid of the problem. no parts have been replaced recently right? check the connector to the logic board this is theeonly 3 pin connector that has black and white wires. this sohlud fix your problem
Posted on Nov 28, 2009
I recently replaced my ink cartridges for my Lexmark X2500 with brand new ones, Lexmark brand, I inserted them and followed instructions and now it still tells me that it can not print that I need new...
  • Open up the "Printer Solution Center." If there is no icon on your desktop for your Lexmark printer, click on the "Start" menu button, which is located at the bottom left-hand corner of the screen. Click on "All Programs," and then look for "Lexmark." Select the "Printer Solution Center.
    Choose "Install a new printer cartridge" under the "Maintenance" tab.
  • Click on "Next" until you see the "Print the Alignment page" option, then choose "Print."
  • Repeat steps 1,2 and 3 if the ink level gauge still isn't showing sufficient ink.
  • Apr 13, 2011 | Lexmark X2500 All-In-One Printer
    I replaced both cartridges in my x2500 with new cartridges but the printer still says I need to replace them. What to do?
    Your cartridge nozzles may need to be cleaned. Open the Lexmark Solution Center. From the Maintenance tab, click Clean to fix horizontal streaks. Click Print. A page prints, forcing ink through the print cartridge nozzles to clean them.
    Apr 11, 2011 | Lexmark X2500 All-In-One Printer
    Color ink want print after installing new cartridge
    have you installed the cartridge correctly??? make sure you did
    try to print a few pages, to get the ink going.
    try test pages, try the aligning procedures as well.
    Mar 26, 2009 | Lexmark Z515M InkJet Printer
    Changed ink cartridges cannot print alignment page, out of ink
    You need to reset the ink level before the printer can print further, to do these please follow the following step:
    1) Goto the Lexmark Solution Center application.
    2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
    Then try again with printing alignment task.
    Hope this help.
    YBC (/\)
    Feb 26, 2009 | Lexmark X2500 All-In-One Printer
    Lexmark x2500 invalid cartridges
    I am out of ink for my printer the numeber is 28 black 29 color
    Nov 23, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark x2500
    To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
    Nov 04, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark X2500 All-In-One. Re-filled print cartridge
    These are new cart in these Lexmark printer which will not accept any refilling only way to get the printer working is to use original Lexmark cart ...
    Good luck...
    Aug 25, 2008 | Lexmark X2500 All-In-One Printer
    Unsupported cartridge error
    I have an X5495 Lexmark and have recently been getting this **** "unsupported cartridge" rubbish. OS is XP SP2.
    My history with this printer has been:
    -when new, the printer worked fine until I needed to replace the original ink tanks. I refilled them, but could not get the printer functional again....nil print at all. After much frustration, I was informed by a little birdie that the cartridges that originally come with the printer will not work if refilled. Great. They are one use only.
    -replaced with genuine high yield tanks. Then worked fine. Refilled once, possibly twice with suitable non genuine ink. Still working fine.
    -once black ink tank ran low this time, refilled it and symptoms of no print from Word docs, not all parts of a web page would print. Surprisingly, photos off hard disc print ok.(??????)
    -replaced black with genuine tank and colour with remanufactured tank. Error message of "unsupported tank". Now no print at all.
    -left new genuine black cartridge in and refitted genuine colour cartridge that I have previously refilled.
    -all print now ok.....finally.
    Maybe they have a copy limit or the integrated print head in the black has crapped itself????????
    During this process, I have uninstalled and reinstalled the driver several times.
    I have found that it has to be COMPLETELY uninstalled. Using the Lexmark uninstall function does not remove all parts of the software (Lexmark toolbar for one). If the software is not completely uninstalled, you will get a spurious unrelated and rubbish pop up that installation cannot continue because of "insufficient processor speed" with a spurious set of numbers after it. This message bears no relation to the solution.
    I have found that you need to search and delete ALL Lexmark files that you can find after the uninstall. I have also deleted entries from registry.....1 entry only from memory (be CAREFUL with registry). Then reboot system.
    The driver should then reinstall correctly and fully.
    Why do they make it so damn hard? Don't think I'll buy a Lexmark next time.......
    Sep 05, 2007 | Lexmark X2350 All-In-One InkJet Printer
    Lexmark X2500 All-In-One Printer Logo
    126 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
