Back to:
Tags:
PC Desktops
Generic problem for all PC Desktops
I need thew drivers to
posted by Tank123 on Jun 15, 2008
I need thew drivers to make my headset work. It worked just fine until 3 days ago when they stoped working. This is the modle number gigaware drivers 43-122
Comment by Tank123, posted on Jun 17, 2008
The MOBO is a neo 880 I can't even find the drivers there. any other ideas would be appreciated. Thank you by the way.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 15, 2008
Thanks for Trying (70)
samisam
Rank:Wiz Wiz
Rating: 81%, 46 votes
If it stopped working then uninstall it the audio drivers in device manager and right click on any device and select scan for hardware changes. that should hopefully pick it up. if not, find the manufacturer of your motherboard (if it's a built in sound card) and reinstall the drivers.
Rating Locked! (?) Tank123 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on I need thew drivers to:
I don't want to Accept this solution
Can you Help with these PC Desktops problems?
E-Machines eMachines Desktop PC
turn off sleep mode
NEC PowerMate ES SlimLine PC Desktop
le son est tr?s faible et avcec des gr?sillements
PC Desktops
My toshiba M100 laptop screen does not comes on sometimes...
PC Desktops
my toshiba M100 laptop does not comes on sometimes when...
PC Desktops
my toshiba M100 loptop screen does not comes on sometimes...
Loading problems.
Repair Service
Find PC Desktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
