Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a JD 5303 tractor and the three point hitch is in the up position and won't go down. I have tried the adjustment under the seat and that did not work. The tractor has less than 200 hours on it.
5 Suggested Answers
  • 143 Answers
SOURCE: Three point hitch on 2020 Jogn Deere Tractor will not raise.
IF the rest of the hydraulic system has normal pressure, then the control valve for the 3 point may be faulty, or ; the hydraulic cylinder that raises/lowers the 3 point arms has failed (the sealing ring on the internal ring has torn)
Posted on Jun 20, 2009
RonPark
  • 855 Answers
SOURCE: Manual needed for JD 3 bottom plow w 3 point hitch
The first thing to do is get all the information you can off your plow. Like: serial number, model number and any info on any tags you find then go to the John Deere web site. Go to the plows section and you should find everything you need. They do have parts lists and manuals on the site. But it may be harder to find parts without at least a model. But they do have help areas you can try. Try there and if no luck try to give me all the info you can about what you are looking for and I'll do some research for you.
Posted on Sep 13, 2009
  • 146 Answers
SOURCE: JD 3320 tractor with error code 57
From what I can find, that is a 'timeout' error indicating the expected signals from the hydrostatic transmission are not being received. That would suggest that some of the wiring is still not repaired. Could it be the nice doggie pulled out a connector partially and you didn't notice? Make sure all connectors are firmly seated.
Some have seen this error code occur for the simple reason that the battery voltage was borderline low -- those computers are sensitive. So before you take it to the dealer, put the battery on a charger overnight to see if that resolves it.
Hope this helps. If so, please rate my solutions, thanks and good luck!
Posted on Jun 09, 2010
  • 3 Answers
SOURCE: I cannot get the three point hitch on my tractor
HAVE YOU TRIED ADJUSTING THE DOWN SPEED? ON MY
1967 JD 2020 THE ADJUSTING SCREW IS LOCATED AT THE
CENTER OF THE TRANSMISSION CASE BELOW THE FRONT EDGE OF THE SEAT. LOOSEN THE LOCK NUT AND
ADJUST THE SCREW TO OBTAIN THE DESIRED SPEED.
Posted on Jan 02, 2011
My 3 point hitch is stuck in the up position
Most smaller riding tractors and mowers with 3pt hitches have a drop speed vale on them. If this valve is closed completely then the hitch will not drop. Opening the valve lets the hitch drop faster the more it is opened. the valve might be just under the front of the seat and have a knob to turn it
Oct 30, 2015 | Garden
How do I get to three point hitch to apply down pressure on the implementI
3 Point Equipment - Tractor Supply Company
www.tractorsupply.com/tsc/.../3-point-equipme...
Tractor Supply CompanyTSC has 3 point tractor disc, trechers, forks, attachments and implements for sale every day. ... modern farming as much as the adoption of the three-point hitch.3 Point Landscaping & Utility ... - ‎3 Point Cutters & Hay ...
Oct 01, 2015 | Toys
Three point hitch when up all the way the pump continues to. Pump
Springs, or valve seats in the control valve need repair. Or at least my wild guess, with some understanding of hydraulics, in general.
Mar 25, 2015 | John Deere Garden
How to adjust mahindra 5005 three point hitch down pressure?
1 Draft sensing lever in wrong position
Move lever to "light" position.
2 Rate-of-drop too slow
Adjust rate-of-drop valve.
3 Center link on upper front hole
Move center link to lower hole.
4 Draft control out of adjustment
Refer to service manual for adjustment procedure.
5 Internal mechanical interference with load control linkage
Refer to service manual to find interference, or possibly linkage coming apart.
6 Load control shaft or tube broken or bent
Replace load control shaft or tube. Refer to service manual.
7 Load sensing pin malfunctioning, or bad connections - only applies to newer tractors
Replace load sensing pin, repair faulty connections. Refer to service manual.
Aug 13, 2014 | Garden
Three point hitch wont lower, kubota l2550
Mine did the same thing. Below the front of the seat is a knob sticking toward the front of the tractor that is angled upward that controls the fall rate of the three point hitch. After searching the internet for a while I found what this knob is for and went out and turned it until the three point fell down. The knob is perfectly placed to bump with my foot as I get off the tractor (I have large feet and bump a lot of controls getting on and off) and I guess I had bumped it closed over time.
Dave
Jun 22, 2012 | Garden
I cannot get the three point hitch on my tractor to come down. The internal and external controls will not work and even heat will not loosen it up
Jan 02, 2011 | John Deere 420,1020,2010,2020,2510,2520...
Pto, fuel gauge, three point hitch all stop functioning at the same time
check the acc fuse
also check wires under seat because of short in them will not let pto work
Jun 17, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
Jun 09, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Sep 13, 2009 | Garden
3 point hitch wont lower
Some of these tractors have a knob under the seat that locks the three point up so it cannot be lowered by accident. Check for this knob and open it.
Mar 27, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
531 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
