Question about Refrigerators
House filled with smoke and smelt like an electrical Fire. Had the fire department down. Appear my Fridge was still running however everything in the freezer was thawing and the fridge was warm. I believe it may be the compressor burnt out? I have only had this for about 6 years (rediculous)
  • 4,793 Answers
Hi Tina,glad your still here to make the comment.....next item you buy,fit a circuit breaker,so if you get a short it will blow.they are fairly cheap.(in the UK)same as you use for an electric mower.
Posted on Nov 06, 2010
Why does my microwave keep tripping my breaker?
Because you have a short inside the machine.
Please do not turn it on again until you have it repaired, or replaced. Otherwise, you may be calling your fire department because of an electrical fire in your house or apartment.
You have received this message from a retired fire chief.
Dec 15, 2016 | Microwave Ovens
Fridge freezer exposed to fire smoke and not cooling down
Sounds like you may possibly have caused some damage when you cleaned it up - can you talk us through exactly what you did to it and how badly it needed "cleaning" - was it caked in soot etc. How hot do you think it got during the fire? if it got much above 60 celcius for any length of time what can happen is that the refrigerant gas boils enough that it will overwhelm all the seals. only real way to check is get a fridge repair guy to test it for leaks and refrigerant content, be careful not to run it too much in case this is the problem - can be fixed but running it won't do it any favours. Hope this helps, please post back with a bit more detail and hopefully we will have more of an idea what the problem could be :)
Jun 26, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
System is old need a replacement I can't seem to open, is there a battery replacement or a replacement alarm available
to open fire alarms twist the case to the left and it comes apart
consider this
if the alarm is old , it has been superseded with a better model that works on a different principle to smelling the air to detect smoke
Discuss the advantages of installing the new and different version with any fire prevention company or your local fire department
IN many instances a combination of both ensures protection of the people in the house
Dec 01, 2015 | Home
Woodchief stove
It could be a draft issue . In order to work properly the stove needs to be able to draw air in to replace the airgoing up the chimney along with the smoke from the fire. In old houses this was not a problem be cause they were loosely constructed and replacement air could be drawn in around windows and doors and gaps in the walls. Newer homes are a lot tighter therefore no replacement air can get in. In some cases the house is so tight that running an exhaust fan or dryer actually creates what is known as a negative pressure situation if this is the case air can be drawn backwards down the chimney and into the house bringing the smoke from the fire with it. To check for this try starting a fire with a window or door partly open. If the fire drafts correctly you may have to install a make up air for the stove. Hope this helps.
Dec 08, 2013 | Heating & Cooling
My Frigidaire Washer began pouring out smoke. Smelled like burnt rubber and the smoke from the garage filled my home. Had to call out fire department. not an electrical issue
The bearing on the main spindle probably seized and the motor continued running and burned up the belt. The belt will need to be replaced, and whatever caused the issue in the first place will need to be remedied weather it was a bearing or something else.
Mar 22, 2012 | Frigidaire GLET1142CS Top Load Stacked...
Central AC unit sent smell and smoke film
thermostat can short out turning on system a short in wiring will do same --smoke can be from fan or circuit board have a mechanic service the system
Jun 11, 2017 | Carrier Adit 600 Base +24V Phone...
I placed yam to microwave - left room and came back to see yam on fire (black as coal) and now my microwave control panel does not work - the yam was on fire before I put it out. filled the house with...
my son did the same with a conker /horsechestnut micowave full of soot kitchen full of smoke microwave was no more / the soot got in to everything just had to replace it
Jan 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Not cooling after smoke damage
Assuming that the motor is running, my best guess would be that the condenser (a large grid of thin piping) was covered in soot, and should be THOUROUGHLY cleaned, preferably with compressed air.... The condenser will either be underneath the unit, behind a small panel in the front bottom of the unit, or at the back behind a cover at the bottom of the fridge which runs the whoile width. Make sure the fan at the back near the compressor is also running....if the condenser fan is not running when the compressor is running, it won't cool. If the condenser is excessively dirty, it won't cool!
Jun 26, 2007 | Frigidaire PLHS269ZC Side by Side...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
