Question about Kirby Shampooer Shampoo Hose G3 Ultimate Diamond Vacuum
The tray keeps coming off the vacuum while I'm shampooing and does the belt need to be loose or tight
4 Suggested Answers
b0sslady2001
  • 357 Answers
SOURCE: Vacuum brush roller with belt attached is off
Here is a very clear online instruction guide for the shampooer. Hope this helps!
Marci
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Posted on Nov 09, 2007
reddevil6
  • 1673 Answers
SOURCE: New Eureka vacuum cleaner belt keeps slipping off
You may have a bad brush roll, part #61250-1, or the base itself has a problem and isn't letting the brush roll sit straight so it can be in alignment.
Posted on Jan 15, 2008
b0sslady2001
  • 357 Answers
SOURCE: I have a Kirby vacuum with the shampooing attachment. The shampoo/liquid comes out of the shampooer in a drizzle of liquid. There is no foam.
You need to check that the little round screen is in the hole where the hose attaches to the shampoo tank. My guess is that the little round screen is wedged sideways in the end of the hose. Here is a guide to help you further... http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Posted on Jun 28, 2009
Shampoo part wont stay attached, keep coming apart, brand new about 1 year!
If the tray comes off the machine this is caused by a stretched belt, customers forget get to take of the tension of the belt when not using the shampooer, if left on the belt lifter hook it streches the belt. fit a new kirby genuine goyshan belt
Dec 28, 2015 | Kirby Style F 2009-Newer Sentria Allergen...
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
Kirby not shampooing, no suds coming out.
Make sure the tray is all the way down. Step on the toe petal to adjust. Turn on power assist.Turn sud control valve right to increase suds.
Apr 27, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby
machine will not come on
Sep 04, 2008 | Kirby G6 Bagged Upright Vacuum
I need to learn how to use the kirby G4 shampoo system. I was given the vacuum without instructions.
firstly remove the original front by turning the square at the front so it reads belt off then replace it with the shampoo front tray after that take of the bag and replace with the shampoo bottle the small pipe fits one end on the bottle one end on to the tray fill your bottle up with shampoo and just use as you would when you are hoovering
Sep 04, 2008 | Kirby Vacuums
How do i put together my kirby carpet shampoo system?
Vacuum thoroughly before shampooing for maximum cleaning. Then, remove the bag and the Power Nozzle to prepare for shampooing. Turn the Carpet Shampoo System Nozzle Belt Lifter to the right of the center position (fully clockwise) until the green arrows line up. a4bbc62.jpg Slide the slots on the side of the Carpet shampoo system over the outer shoulders of the Carpet Shampoo System Tray. e14fe2e.jpg While pushing up on the Belt with your finger, turn the Belt Lifter left (counter- clockwise looking at it from the front) until the red arrows line up. (The Belt Lifter Hook will catch and stretch the belt.)
Press the bottom Toe Touch Pedal all the way down to raise the front of the Kirby.
While sliding the carpet shampoo system Nozzle/Tray Assembly toward the Kirby and over the Motor shaft, connect the hooks on the bottom rear of the nozzle to the Attaching Bar.
Push the nozzle up against the Kirby and turn the Accessory Lock to the
right (clockwise) to lock the nozzle in place. To engage the belt, turn the Belt Lifter
all the way to the right (clockwise) until the green arrows line up. Then lower the Headlight Hood
Apr 18, 2008 | Vacuums
Bissell 1698 Powersteamer no spray
A simple thing to check is make sure the round seal is on the bottom of the tank, it needs to be on the tank not sitting loose in then hole that the tank valve goes into. Could be a problem with the flow indictor cap leaking air. Is the top and the base tight together in the back, sometimes the plastic breaks loose and the top will rise enough that it raises the tank so water won't flow. Your pump may be bad.
Mar 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
It is meant to come apart for cleaning it up afterwards. Slip the belt over the roller. One triangular end of the roller is bigger than the other, so keep this in mind when sliding it into the cleaning head. Turn the knob to pick up the belt, just like on the vacuum's regular nozzle. Mount the cleaning head, then turn the knob to set the belt onto the motor spindle.
Apr 02, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Shampooer Shampoo Hose G3 Ultimate Diamond Vacuum Logo
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
