Question about Kenmore 24032\24036 Top Load Washer
How do you get the back off of a kenmore washer
    President:
  • 1,430 Answers
You take the front cabinet off. Try this video
Disassembling a whirlpool style washer
Posted on Nov 06, 2010
Replace mixing valve
If this is a Kenmore top loader such as the one pictured, you need to remove the exterior washer case in order to access the mixing valve. DO NOT attempt to remove the back pnel as these washers are not designed to have the back panel removed. The following link explains step-by-step how to access and replace the valve:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
I could not find an exact match for the model number you provided, but most Kenmore top loaders are configured the same regardless of features.
If you have any questions about this repair, or if your washer configuration is different from what I have described (i.e., if this is a Calypso, Cabrio or Oasis), please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool, so these instructions do apply.
Apr 02, 2010 | Kenmore 23822 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
Hi, Make sure the washer is solid to the floor. To level the washer, Put your foot against the front panel at the floor and tip the back of the washer toward you. Then set the washer back down and the rear legs should self adjust.
Hopefully this will stop the washer from shaking.
Vic
Jun 30, 2009 | Kenmore 24032\24036 Top Load Washer
Removing the top of a Kenmore Elite Oasis Washer to replace hose
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Removal of back panel on kenmore two speede washer
It does not come off.
Use the video attached to access the inside of the washer.
Apr 24, 2009 | Washing Machines
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Top load kenmore 110
it's your pump! thats the most common leak on kenmore top loaders.it located low ,front and .you can tip washer back towards wall and inspect.the pump is white and has two hoses to it.
Jan 24, 2009 | Kenmore 22422 Top Load Washer
I need to remove the back panel on my top load kenmore washer
5
6
7
Jan 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Model 417.44072300 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer Kenmore Model 417.44072300 Front load washer.
The drum is loose. I pulled the back panel off and the nut is tight behind the drum? could it be the bearing? do I need to change the whole drum? is this a common problem or was this do to abuse.
Jul 28, 2008 | Kenmore 46462 Front Load Washer
Plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Jan 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 24032\24036 Top Load Washer Logo
69 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
