Question about Kenmore 74952 / 74954 / 74956 Gas Dryer
Dryer runs but no heat,replaced the ignitor,no heat,what next. and how do you get the back of this unit apart
    President:
  • 3,074 Answers
Http://www.applianceaid.com/gas_dryer.html#noheat
Posted on Nov 06, 2010
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a whirlpool LGR8648pwo. Runs not heat and timer doesnt move. I found a 4 prong sensor in the back of the unit. 2 prongs have continuity and the other 2 dont. Is that bad.
If no heat at all i suspect this part HERE. This is the fuse. It kills power to the gas assembly if junk gets into the filter housing and cause an overheat condition. On electric models this same fuse kills the whole dryer. On gas models it just kills the gas. If that is good the next thing to check is the flame detection sensor mounted out side of the burner chamber. It's job is to power up the ignitor. If it is open no power can get to the ignitor. If it is good then the next thing to check is the ignitor. If the ignitor is good AND you are getting power from that control klixon you mentioned with the 4 wires on it AND you can get a little heat at first but then none at all them coils need to be replaced. Here is my home video:
Dec 09, 2012 | Whirlpool LGR8648 Gas Dryer
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
LGR7646EQ0 Dryer runs but no heat (new ignitor)
check all the thermal fuses with an ohm meter if one of then is not showing any continuity the replace it this should help good luck
Jan 23, 2010 | Whirlpool LGR7646E Dryer
Dryer shuts off after about 5-10 minutes of running. The top of the dryer is hot.
Howdy: There is a thermostat inside the unit in the back. If this has lint clinging to it, it will shut off unit. Also the firing ignitor has two soleniods
that stick and turns off unit too early. But with the top of dryer hot I would say the heat always stays on and the thermostat shuts off ignitor. The firing should be a pulse type heat, not a constant heat. Good luck - Doug
Dec 08, 2009 | Kenmore Dryers
Have a Kenmore Gas Dryer 80 series, model # 110.78842990 that runs but has no heat, have torn everyting apart and cleaned out all the lint, but still no heat.
Burner not lighting/staying lit. Most likely the ignitor.
Check out
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
Maytag dryer runs but doesn't heat up
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 05, 2009 | Maytag PYE2300AY Electric Dryer
Dryer doesn't heat...
Check the following to address this issue--
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 03, 2009 | Frigidaire FGR211AS Gas Dryer
IGNITOR
To get to the ignitor, you must remove the front panel. To do this, first open the door and remove the two screws and plastic tabs that are directly across from the door hinges (left side if rt hand swing door and right side if left hand swing door). Next, support the door and remove the two screws from the hinges and remove the door. The front panel is now loose and will pivot down from the top out. Pull it out a couple inches then straight up and out of the way. You now have access to most all of the components internal of your dryer, including the ignitor. I know it's late, but didn't see an answer for it yet....and I have mine apart right now for the same problem (runs with no heat).
Aug 11, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won heat timer dosen't avance
huntman, the model posted shows as a gas dryer. In the lower left side there is a square plastic peep hole. Take a putty knife and pull it off. Set the dryer to high heat and take a look in the hole. Does the ignitor glow? If it doesn't you either have a bad thermal fuse or a bad ignitor. Start with the thermal fuse. You will have to remove the back panel to get at it. I will attach a photo. You can ohm it out, or just jump the wires temp. to see if the ignitor glows. If theral fuse is good and the ignitor does glow, you probabley have a bad set of coils. These sit on the gas valve are easy to replace. The timer won't advance without the heat. Check this out first...Catriver..post back.
Mar 15, 2007 | Roper RGS7745PQ Dryer
Kenmore 74952 / 74954 / 74956 Gas Dryer Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
